土木在线论坛 \ 电气工程 \ 供配电技术 \ 有没有见过这样的负荷计算的?
有没有见过这样的负荷计算的?
发布于:2014-03-16 19:48:16 来自:电气工程/供配电技术 [复制转发]
最近做了一个国外住宅的工程。那边说我的计算错了。然后发了一个要求给我。看了一下,好像跟国内的需用系数法差不多。请问有没有同行见过类似做法的?下面的中文是我用在线翻译做的。供大家参考。若有
BD 43-102-07
PRIVATE LAOD OF ELECTRICITY CALCULATION FOR RESIDENCE BUILDING (KW/each unit)
Table 6.1
No
Electricity user
Private electricity load of unit calculation, unit numbers
1-5
6
9
12
15
18
24
40
60
100
200
400
600
1000
Unit with natural gas stove 采用天然气炉
4.5
2.8
2.3
1.65
1.4
1.2
1.05
0.85
0.77
0.71
0.69
0.67
Liquefied gas (particle equipment, solid fuel) 液化天然气(颗粒设备,固体燃料)
6
3.4
2.9
2.5
2.2
1.4
1.3
1.08
0.84
0.76
8.5 KW electricitycapacity
10
5.1
3.8
3.2
2.8
2.6
2.2
1.95
1.7
1.5
1.36
1.27
1.23
1.19
Cottage
1.7
1.4
1.2
1.1
0.9
0.76
0.69
0.61
0.58
0.54
0.51
0.46
Note:
1. Intermediate valueisdeterminedbyinterpolation method. 中间值是实验室内插法
2. Public property (stage area, basement, technical floor, ceiling etc), room lighting, weak power, low voltage equipment (fire resistance equipment board, automatic, heating meter board, rubbish pipe cleaning equipment, lifting equipment of disabled people etc) were calculated in the private load of unit calculation. 公共财产(舞台区,地下室,技术层,顶棚等),室内照明,弱电,低压设备(防火设备板,自动加热,仪表板,垃圾清管设备,残疾人等起重设备)在单位计算私人负荷计算。
3. Private calculation load is calculated asaverage 70m2area (35m2-90m2). 计算负荷的计算平均面积(70私人35m2-90m2)
4. Calculation load of luxury residence should be determined and suited to drawing task or specified capacity, consumer demand and simultaneous ratio. (Table 6.2, 6.3)
5. Each residence room wasn’t calculated for livingin the private calculation load. 每个住宅房间不计算在私人的计算负荷。
6. Total demand load and installed (plugged) public building’s lighting and power load, advertising, decoration, as well as electric heaters, water heaters and domestic use of air conditioning equipment in the unit (except the luxury building) are not calculatedin the private calculation load. 总负荷需求和安装(插入)公共建筑的照明及电力负荷,广告,装饰,以及电热水器,热水器和家用单元中的空调设备的使用(除了豪华的建筑)不在私人的计算负荷的计算。
7. If necessary, when calculate the peak load of morning andafternoon, electricity stoveuse the 0.7coefficient, gasandsolidfuelstoves usethe 0.5coefficient. 如果有必要,在计算的上午和下午的高峰负荷,电炉使用系数0.7,气体和固体燃料炉用0.5系数。
8. During thesummerpeakload, when calculate the electricity load,natural gas stove use coefficient0.7; fuel gas and solidfuelstoveuse0.6; electric stoveuse0.8 asreduced the winter maximumloadto calculate. 夏季尖峰期间,当计算电力负荷,天然气炉利用系数0.7;燃料气体和固体燃料炉使用0.6;电炉使用0.8减少冬季最大载荷计算。
9. Calculation datashowninthetablecan be adjustedbasedonlocalconditions.According to the proper regulations, if you have the documented and approved test result, you can use the test result to calculate. 计算数据表中所示可以根据当地的条件进行调整。根据适当的规定,如果你有记录并获得批准的测试结果,你可以使用测试结果来计算。
10. 10KW decoration lighting load cannot be calculated in building’s input calculation load.
Required coefficient of Luxury residence
Table 6.2
Specified capacity, KW
<14
20
30
40
50
60
More than 70
0.8
0.65
0.6
0.55
0.5
0.48
0.45
Parallel coefficient of Luxury residence loadK0
Table 6.3
Residence specification
K0, residence number
1-5
6
9
12
15
18
24
40
60
100
200
400
More than 600
Electric stove
0.38
0.32
0.29
0.26
0.24
0.2
0.18
0.16
0.14
0.13
0.11
Feed pipe of Luxury residence, calculationloadof inputand0.4kWsubstationsdistributionfacilityshould be determinedbythefollowingformula. 豪华住宅,投入0.4kw变电站配电设备的计算负荷应采用以下公式。
(PT.TC),KW.
全部回复(28 )
  • 电气老孙
    电气老孙 沙发
    看来有不少和我一样啊,英语是硬伤啊!
    2014-05-14 07:41:14
  • wangzhiqungz
    wangzhiqungz 板凳
    呵呵,好久没看了,竟然有人关注这个帖子。其实他们也是一样的,都是采用需用系数法设计的,只是,他们直接将系数转换成功率。感觉他们的洗漱选择更为小一些。貌似他们有经过测算的。不像我们国内的系数越取越不合理。现在国内供电部门系数取值最小只能0.5.:lol
    2014-05-13 23:02:13
97.93 万条内容 · 2230 人订阅
奇怪的电表——无负载电表反转
请教各位:我这里的电表是单相的,相、零线从铜牌接经过电表后相线接一个1P的空气开关再到商户(零线表后直接到商户),现在碰到一个问题,有几个电表的空气开关断开后电表出现了反转,后来我把表的零线进线和出线拆除还是一样,我测过电流是0.055A左右。请问各位是什么原因?有好几个都一样。
