土木在线论坛 \ 建筑结构 \ 钢结构工程 \ 多层钢框架,刚度比超限,形成薄弱层SATWE自动调整后,是否需要做弹塑性分析
发布于:2013-11-20 10:26:20 来自:建筑结构/钢结构工程 [复制转发]
各层刚心、偏心率、相邻层侧移刚度比等计算信息
Floor No : 层号
Tower No : 塔号
Xstif,Ystif : 刚心的 X,Y 坐标值
Alf : 层刚性主轴的方向
Xmass,Ymass : 质心的 X,Y 坐标值
Gmass : 总质量
Eex,Eey : X,Y 方向的偏心率
Ratx,Raty : X,Y 方向本层塔侧移刚度与下一层相应塔侧移刚度的比值(剪切刚度)
Ratx1,Raty1 : X,Y 方向本层塔侧移刚度与上一层相应塔侧移刚度70%的比值
或上三层平均侧移刚度80%的比值中之较小者
RJX1,RJY1,RJZ1: 结构总体坐标系中塔的侧移刚度和扭转刚度(剪切刚度)
RJX3,RJY3,RJZ3: 结构总体坐标系中塔的侧移刚度和扭转刚度(地震剪力与地震层间位移的比)
Floor No. 1 Tower No. 1
Xstif= 28.9420(m) Ystif= 17.7219(m) Alf = 0.0000(Degree)
Xmass= 29.5731(m) Ymass= 19.3248(m) Gmass(活荷折减)= 1606.5254( 1352.1733)(t)
Eex = 0.0283 Eey = 0.0719
Ratx = 1.0000 Raty = 1.0000
Ratx1= 0.9828 Raty1= 1.0124
薄弱层地震剪力放大系数= 1.25
RJX1 = 1.4046E+06(kN/m) RJY1 = 1.4046E+06(kN/m) RJZ1 = 0.0000E+00(kN/m)
RJX3 = 1.6099E+05(kN/m) RJY3 = 1.5405E+05(kN/m) RJZ3 = 0.0000E+00(kN/m)
Floor No. 2 Tower No. 1
Xstif= 30.0000(m) Ystif= 22.5557(m) Alf = 45.0000(Degree)
Xmass= 29.9207(m) Ymass= 21.9232(m) Gmass(活荷折减)= 1392.7949( 1180.6530)(t)
Eex = 0.0037 Eey = 0.0293
Ratx = 1.1759 Raty = 1.1759
Ratx1= 1.4306 Raty1= 1.5424
薄弱层地震剪力放大系数= 1.00
RJX1 = 1.6516E+06(kN/m) RJY1 = 1.6516E+06(kN/m) RJZ1 = 0.0000E+00(kN/m)
RJX3 = 2.3402E+05(kN/m) RJY3 = 2.1736E+05(kN/m) RJZ3 = 0.0000E+00(kN/m)
Floor No. 3 Tower No. 1
Xstif= 29.3682(m) Ystif= 21.9337(m) Alf = 0.0000(Degree)
Xmass= 29.9254(m) Ymass= 20.8446(m) Gmass(活荷折减)= 1224.7234( 1030.5154)(t)
Eex = 0.0261 Eey = 0.0510
Ratx = 0.9381 Raty = 0.9381
Ratx1= 2.5263 Raty1= 2.9770
薄弱层地震剪力放大系数= 1.00
RJX1 = 1.5493E+06(kN/m) RJY1 = 1.5493E+06(kN/m) RJZ1 = 0.0000E+00(kN/m)
RJX3 = 2.3368E+05(kN/m) RJY3 = 2.0132E+05(kN/m) RJZ3 = 0.0000E+00(kN/m)
Floor No. 4 Tower No. 1
Xstif= 28.7611(m) Ystif= 20.2120(m) Alf = 45.0000(Degree)
Xmass= 21.2310(m) Ymass= 20.4265(m) Gmass(活荷折减)= 394.1938( 362.7199)(t)
Eex = 0.3993 Eey = 0.0114
Ratx = 1.1313 Raty = 1.1313
Ratx1= 1.0000 Raty1= 1.0000
薄弱层地震剪力放大系数= 1.00
RJX1 = 1.7528E+06(kN/m) RJY1 = 1.7528E+06(kN/m) RJZ1 = 0.0000E+00(kN/m)
RJX3 = 1.3214E+05(kN/m) RJY3 = 9.6605E+04(kN/m) RJZ3 = 0.0000E+00(kN/m)
X方向最小刚度比: 0.9828(第 1层第 1塔)
Y方向最小刚度比: 1.0000(第 4层第 1塔)
全部回复(3 )
  • chinalxb
    chinalxb 沙发
    不能一味的关注这几个指标,一定要结合房屋的使用情况、支承的设备情况等综合考虑,关键在于概念设计。
    2014-07-17 14:34:17
  • zengliangsg
    zengliangsg 板凳
    学习了,多层真纠结
    2014-07-17 11:58:17
钢结构工程
46.53 万条内容 · 1224 人订阅
求高人做一个类似结构3D演示的东西
老板要的,我也不懂这个。这里的高手应该比较多,过来试试。有意联系邮箱ngejsb@163.com
