土木在线论坛 \ 电气工程 \ 供配电技术 \ 电动机启动方式求助
请教论坛的各位专家们,我们遇到一个项目业主要求15-60KW的电机使用ASD启动器,这里面的ASD启动器是什么意思?
全部回答(4 )
  • lesonlee
    個人觀點-僅供參考~
    從wiki motor controller
    得到解釋如下:
    An adjustable-speed drive (ASD) or variable-speed drive (VSD) is an interconnected combination of equipment that provides a means of driving and adjusting the operating speed of a mechanical load. An electrical adjustable-speed drive consists of an electric motor and a speed controller or power converter plus auxiliary devices and equipment. In common usage, the term “drive” is often applied to just the controller.
    這裡應該是個還在揣摩的先進技術
    (此等級運用至今還無納入IEC or IEEE)
    當然需要業主確認其所需要的程度
    2013-11-19 13:09:19 来自 PC 评论 举报
  • dongge6666
    ASD是个伺服交流启动器!以PM型伺服马达为主力,控制回路采用高速数字信号处理器DSP控制!
    2013-11-19 10:45:19 来自 PC 评论 举报
97.93 万条内容 · 2230 人订阅
