土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 关于高规9.1.11条,这个剪力标准值最大值指的是分段内的各层中最大值还是每一层
发布于:2013-10-24 16:43:24 来自:建筑结构/混凝土结构 [复制转发]
27 1 X 159.7 159.7 100.00%
Y 143.0 143.0 100.00%
26 1 X 242.3 428.5 56.54% 4677.8 5.18%
Y 223.2 362.7 61.54% 3965.1 5.63%
25 1 X 455.2 877.3 51.89% 4677.8 9.73%
Y 460.6 723.0 63.71% 3965.1 11.62%
24 1 X 565.7 1354.6 41.76% 4677.8 12.09%
Y 577.7 1119.1 51.62% 3965.1 14.57%
23 1 X 573.5 1722.5 33.30% 4677.8 12.26%
Y 585.4 1424.7 41.09% 3965.1 14.76%
22 1 X 594.5 2011.1 29.56% 4677.8 12.71%
Y 627.4 1672.0 37.52% 3965.1 15.82%
21 1 X 617.6 2233.1 27.66% 4677.8 13.20%
Y 666.7 1873.1 35.59% 3965.1 16.81%
20 1 X 585.3 2404.4 24.34% 4677.8 12.51%
Y 649.8 2038.2 31.88% 3965.1 16.39%
19 1 X 714.2 2548.5 28.02% 4677.8 15.27%
Y 803.6 2181.9 36.83% 3965.1 20.27%
18 1 X 676.4 2670.8 25.33% 4677.8 14.46%
Y 771.0 2303.3 33.47% 3965.1 19.44%
17 1 X 688.4 2778.5 24.77% 4677.8 14.72%
Y 796.1 2408.2 33.06% 3965.1 20.08%
16 1 X 690.0 2877.1 23.98% 4677.8 14.75%
Y 796.2 2504.1 31.80% 3965.1 20.08%
15 1 X 708.6 2973.4 23.83% 4677.8 15.15%
Y 820.4 2598.9 31.57% 3965.1 20.69%
14 1 X 704.2 3074.3 22.91% 4677.8 15.05%
Y 830.3 2697.0 30.78% 3965.1 20.94%
13 1 X 700.0 3187.0 21.96% 4677.8 14.96%
Y 836.2 2800.0 29.86% 3965.1 21.09%
12 1 X 691.1 3316.3 20.84% 4677.8 14.77%
Y 839.7 2909.0 28.87% 3965.1 21.18%
11 1 X 687.1 3463.4 19.84% 4677.8 14.69%
Y 848.6 3025.5 28.05% 3965.1 21.40%
10 1 X 643.1 3625.5 17.74% 4677.8 13.75%
Y 804.0 3151.0 25.52% 3965.1 20.28%
9 1 X 745.9 3802.2 19.62% 4677.8 15.94%
Y 949.0 3289.2 28.85% 3965.1 23.93%
8 1 X 676.1 3984.1 16.97% 4677.8 14.45%
Y 891.3 3433.2 25.96% 3965.1 22.48%
7 1 X 658.6 4166.1 15.81% 4677.8 14.08%
Y 879.6 3576.7 24.59% 3965.1 22.18%
6 1 X 621.4 4344.7 14.30% 4677.8 13.28%
Y 851.5 3714.5 22.92% 3965.1 21.48%
5 1 X 563.0 4514.5 12.47% 4677.8 12.04%
Y 812.8 3842.6 21.15% 3965.1 20.50%
4 1 X 617.6 4677.8 13.20% 4677.8 13.20%
Y 849.8 3965.1 21.43% 3965.1 21.43%
3 1 X 639.9 4882.1 13.11% 5086.7 12.58%
Y 741.3 4121.8 17.98% 4282.7 17.31%
2 1 X 471.2 5022.5 9.38% 5086.7 9.26%
Y 620.1 4232.6 14.65% 4282.7 14.48%
1 1 X 686.5 5086.7 13.50% 5086.7 13.50%
Y 765.0 4282.7 17.86% 4282.7 17.86%
9.1.11 抗震设计时,筒体结构的框架部分按侧向刚度分配的楼层地震剪力标准值应符合下列规定:
1 框架部分分配的楼层地震剪力标准值的最大值 不宜小于结构底部总地震剪力标准值的10%。
我现在1~3层是一段,2层不满足10%,这个有没有关系?
全部回复(20 )
  • harmony210
    harmony210 沙发
    1、最大值是每层的最大值(但不包括加强层及相邻上下两层);
    2、各层均小于20%但最大值大于10%时,各层剪力取min(20% , 1.5倍的最大值) 高规9.1.11-3;
    3、包括最大值在内的各层均小于10%,由于最大值太小,无法使用1.5倍的最大值,于是按高规9.1.11-2调整;
    4、部分楼层大于20%,部分楼层小于20%甚至小于10%(最大值肯定大于20%),小于20%的楼层直接按20%调整,高规8.1.4
    有不准确的地方请坛友指正。
    2017-08-12 12:55:12
  • wangbwzhy
    wangbwzhy 板凳
    标准值小于20% 是调整的前提,1:有可能都小于20%。2:有可能部分有小于10%,部分大于10%小于20%,部分大于20%。对于9.1.11.3调整的前提:最大值是不能小于10%的。
    最大值可以这样理解:相对3条,按最大值调整,确保最大值剪力不过小(10%),结合条文说明.各层剪力可以出现小于10%,但调整是按最大值和底部剪力为标准调整各层的,这样各层柱截面就满足二道设防要求。与9.1.11.3条也完全符合。
    觉得合理 不忘了评分哦。
    2016-01-14 10:11:14
140.17 万条内容 · 2232 人订阅
中南大学高层建筑工程设计视频
中南大学高层建筑工程设计视频共15讲
