土木在线论坛 \ 环保工程 \ 水处理 \ 国外的SBR污水处理厂现场图片配合文字说明
发布于:2013-07-12 15:21:12 来自:环保工程/水处理 [复制转发]
  Sequencing Batch Reactor plant
  Kinneil Kerse treatment works is situated at Grangemouth on the Forth Estuary
It overlooks the BP oil refinery
  Treatment is by Sequencing Batch Reactor: after initial screening, both liquid and solid waste is treated in a single large tank.
 Diagram of the sequence of operations in a SBR
  It is aerated for a certain period, then the aeration is turned off and solids settle out. 6.jpg
 Treated effluent is removed from the top of the tank by a floating boom and discharged 7.jpg
Overview of the works: the SBR tank on the right is emptying
  Sequencing Batch Reactors (SBR)
  SBRs are fill and draw activated sludge treatment systems for capacities from 10,000-20,000 GPD. Sequencing Batch Reactor Systems utilize two of more fill-and-draw reactors which are completely mixed. Almost all SBR systems operate in a five-step mode: filling of the reactor basin, a reaction phase,a settling phase, a decant phase, and an idle phase. The reaction phase is usually a combination of aerobic and anoxic phases to achieve high levels of BOD and nitrogen removal.In certain circumstances, the reaction sequence can be modified for phosphorous removal. WSI designs SBR systems that are mechanically robust and completely automated. If required, systems can be configured with sludge dewatering of digestion basins. In special applications, WSI can provide equalization basins to ensure proper sequencing of the SBR system. 9.jpg
水处理
43.47 万条内容 · 1518 人订阅
10年制药企业做环保的一些体会和心得
  xingjf731011的体会与心得  我工作这10年可以见证国家环保政策变化的10年。10年内,国家对环境保护的力度是越来越大。各个单位对环境保护工作的重视也是与日剧增。想想10年以前,。。。。  今天先发表以下自己的感慨,要开会了,以后再谈谈污水处理技术,环境管理等方面的心得吧。偶是从技术做起的,水,沼气,污泥全都接触过,还是有一些经验的。  关于实际的运行经验,先谈谈水处理的事情吧。其实各位都知道在企业中做环保工作,尤其是水处理的具体工作,就像是污水处理站的技术人员吧,应该都有这样的体会,
