土木在线论坛 \ 注册考试 \ 注册土木工程师 \ 水泥词汇英汉对照
水泥词汇英汉对照
发布于:2007-09-09 08:48:09 来自:注册考试/注册土木工程师 [复制转发]
硅酸盐水泥portland cement  主导产品leading product
  年产量annual output
  基准reference
  体系system
  完全燃烧complete combustion
  不完全燃烧incomplete combustion
  机械不完全燃烧mechanical incomplete combustion
  化学不完全燃烧chemical incomplete combustion
  雾化atomization
  雾化介质atomizing medium
  物料平衡material balance
  实际空气量amount of actual air for combustion
  理论空气量amount of theoretical air for combustion
  理论烟气量amount of theoretical burned gas; amount of theoretical flue gas
  形成热heat of formation
  单位热耗unit heat consumption
  标准煤Standard coal
  标准煤耗standard coal consumption
  实物煤耗raw coal consumption
  窑炉的余热利用waste heat utilization of kiln
  干燥周期drying cycle
  焙烧周期firing cycle
  热损失thermal loss; heat loss
  燃烧热heat of combustion
  有效热effective heat
  热效率 heal efficiency
  燃烧效率 combustion efficiency
  一次空气primary air
  二次空气secondary air
  系统漏入空气量false air
  空气系数air coefficient
  废气含尘浓度dust content in stack gas
  热平衡表heat balance table
  热流图heat balance diagram
  回转窑rotary kiln
  窑胭体内容积 inside volume of kiln shell
  窑胴体有效内表面积 effective inside surface of kiln shell
  窑或预热器排出飞灰量 dust emit out from the Kiln or preheater system
  入窑回灰量 dust fed back into kiln system
  飞损飞灰量 amount of flying loss of dust
  生料中可燃物质 combustible components in raw meal
  生料带入空气量 air volume carrying by raw meal
  冷却机烟囱排灰量 dust content emitting from stack of cooler
  煤磨从窑系统抽出的热气体量 hot gas volume from Kiln system for coal mill
  入窑回灰脱水及碳酸盐分解耗热 heat consumption for dehydration and decarbonation for dust fed back into kiln system
  回转窑用煤应用基coal used in rotary kiln system
  立窑shaft Kiln
  漏风系数 false air coefficient
  普通立窑cement shaft Kilt / ordinary shaft Kiln
  机械化立窑mechanized cement shaft kiln
  立窑喇叭口inversed cone inlet of shaft kiln
  立窑单位截面积产量production of shaft kiln for unit cross section
  立窑单位容积产量production of shaft Kiln for unit volume
  白生料common meal
  干白生料耗consumption of drying raw meal
  立窑断面平均风速average velocity in cross section of shaft kiln
  卸料管漏出风量amount of leaked out air for discharging tube
  窑面废气成分composition of combustion gas at the upper in surface of shaft Kiln
  黑生料black meal
  入磨煤量internal fuel amount of raw meal
  半黑生料semi-black meal
  入窑煤量external fuel amount of raw meal
  隧道窑tunnel Kiln
  倒焰窑down draft kiln
  检查坑道inspection pit
  预热带preheating zone
  烧成带firing zone; burning zone
  冷却带cooling zone
  窑车kiln car
  匣钵sagger
  棚板deck
  气幕air curtain
  直接冷却direct cooling
  间接冷却indirect cooling
  窑尾冷风cooling gas in the kiln outlet
  窑内断面温差difference of temperature in cross section of kiln
  进车间隔时间kiln car time schedule
  坯体内结构水含量structural water content in body
  坯体的入窑温度inletting body temperature
  零压面neutral margin
  轮窑annular Kilt / ring Kilt circular kiln
  窑门wicket
  隧追式干燥室tunnel dryer
  湿坯wet green
  干坯dried green
  绝干坯absolute dried green
  普通砖common brick
  窑的部火数number of fire travels in annular kiln
  内掺燃料(简称内燃料)carbonaceous materials added to raw materials
  外投燃料(简称外燃料)external fuel added into firing-hole of a kiln
  焙烧反应热heat of burning reaction
  操作放热损失heat losses in the opening and closing of kiln wicket and firing holes
  隧道式干燥室-轮窑(隧道窑)体系热效率(简称体系热效率)(ηtx)the fmal efficiency of tunnel dryer-annular kiln (tunnel kiln)system
  隧道式干燥室-轮窑(隧道窑)体系单位热耗(简称体系单位热耗)unit heat consumption of tunnel dryer-annular Kiln(tunnel kiln)system
  隧道式干燥室,轮窑(隧道窑)体系单位煤耗(简称体系单位煤耗)(mtxm)unit coal consumption of tunnel dryer-annular Kiln(tunnel kiln)system
  • liujunqi00011
    liujunqi00011 沙发
    是的
    2007-09-19 15:55:19
  • cocolike2001
    cocolike2001 板凳
    水泥可是施工中一定会用到的东西,相信这些资料对朋友们很有用
    2007-09-14 08:18:14
注册土木工程师
6.76 万条内容 · 269 人订阅
英文施工组织设计-新加坡公司
英文施工组织设计-新加坡公司转自天圆论坛
