我用面积为50.3mm2的碳纤维筋放到混凝土中,采用降温法施加预应力时,显示已经有裂缝了,不知道是不是单位弄错了呢
ANSYS
返回版块4.39 万条内容 · 152 人订阅
ansys10.0怎么打开14.5间的模型啊本帖最后由 tttruman 于 2013-3-26 10:07 编辑 请教:我用ansys14.5建立了模型,在ansys10.0上打不开,怎么转换成打得开的文件?:Q谁懂的?告诉我谢谢啦
只看楼主 我来说两句抢地板回复 举报
ET,1,LINK8
ET,2,SOLID65
ET,3,PLANE42
R,1,50.24, ,
R,2, , , , , , ,
RMORE, , , , , , ,
RMORE, ,
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,1.47e5
MPDATA,PRXY,1,,0.3
MPTEMP,,,,,,,,
MPTEMP,1,0
UIMP,1,REFT,,,
MPDATA,ALPX,1,,7e-7
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,2,,4.62e4
MPDATA,PRXY,2,,0.2
TB,CONC,2,1,9,
TBTEMP,0
TBDATA,,0.4,1,3,-1,,
TBDATA,,,,,,,
BLC4, , ,50,50
wpoff,25,25
wpro,,,-90.000000
ASBW, 1
wpro,,-90.000000,
FLST,2,2,5,ORDE,2
FITEM,2,2
FITEM,2,-3
ASBW,P51X
FLST,2,4,5,ORDE,3
FITEM,2,1
FITEM,2,4
FITEM,2,-6
AGLUE,P51X
FLST,5,12,4,ORDE,6
FITEM,5,1
FITEM,5,3
FITEM,5,5
FITEM,5,-6
FITEM,5,8
FITEM,5,-15
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,5, , , , ,1
FLST,5,4,5,ORDE,3
FITEM,5,1
FITEM,5,4
FITEM,5,-6
CM,_Y,AREA
ASEL, , , ,P51X
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
MSHKEY,1
AMESH,_Y1
MSHKEY,0
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
TYPE, 2
EXTOPT,ESIZE,20,0,
EXTOPT,ACLEAR,1
EXTOPT,ATTR,0,0,0
MAT,2
REAL,2
ESYS,0
FLST,2,4,5,ORDE,3
FITEM,2,1
FITEM,2,4
FITEM,2,-6
VEXT,P51X, , ,0,0,500,,,,
TYPE, 1
MAT, 1
REAL, 1
ESYS, 0
SECNUM,
FLST,5,1,4,ORDE,1
FITEM,5,20
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,20, , , , ,1
LMESH, 20
NUMMRG,ALL, , , ,LOW
ALLSEL,ALL
NUMCMP,ALL
FINISH
/SOL
CNVTOL,F, ,0.01,2, ,
ANTYPE,0
NLGEOM,1
NSUBST,10,0,0
OUTRES,ERASE
OUTRES,ALL,1
TIME,5
FLST,2,1,1,ORDE,1
FITEM,2,133
/GO
D,P51X, , , , , ,ALL, , , , ,
FLST,2,1,4,ORDE,1
FITEM,2,20
BFL,P51X,TEMP,-6964
ALLSEL,ALL
SOLVE
FINISH
/POST1
SET,LAST
FINISH
/SOL
FINISH
/POST1
SET,LAST
SET,PREVIOUS
这个是建模计算的命令流
