土木在线论坛 \ 建筑设计 \ CAD下载及教程 \ 安装CAD2012出现内部错误2738怎么办
发布于:2013-03-06 22:51:06 来自:建筑设计/CAD下载及教程 [复制转发]
每次安装至最后时,总是出现“内部错误2738” ,已百度过,试过几个方案,如 运行命令"regsvr32 vbscript.dll" 等,卸载重装net4.0也不行,请各位专家给我把把脉,究竟是什么问题,我用的是win7 64位版,安装的CAD也是64位的,谢谢各位了
下面是错误日志
2013/3/5:23:04:52 liu LIU-PC Launch
2013/3/5:23:06:02 liu LIU-PC === Setup ended ===
2013/3/5:23:05:04 liu LIU-PC === Setup started on LIU-PC by liu ===
2013/3/5:23:05:04 liu LIU-PC Launch
2013/3/5:23:06:02 liu LIU-PC PageOpen LaunchDialog
2013/3/5:23:07:30 liu LIU-PC PageOpen LicenseDialog
2013/3/5:23:07:35 liu LIU-PC PageOpen ProductInfoDialog
2013/3/5:23:07:45 liu LIU-PC PageOpen ProductSelectionDialog2
2013/3/5:23:08:02 liu LIU-PC PageOpen FullProgressDialog
2013/3/5:23:08:02 liu LIU-PC Installing .NET Framework Runtime 4.0 Language Pack: D:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2013/3/5:23:08:49 liu LIU-PC Install .NET Framework Runtime 4.0 Language Pack Succeeded
2013/3/5:23:08:49 liu LIU-PC Installing DirectX Runtime: D:\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/5:23:09:13 liu LIU-PC Install DirectX Runtime Succeeded
2013/3/5:23:09:13 liu LIU-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\liu\AppData\Local\Temp\_AI3C2B.tmp\Media.mst"
2013/3/5:23:09:33 liu LIU-PC Install Autodesk Material Library 2012 Succeeded
2013/3/5:23:09:33 liu LIU-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\liu\AppData\Local\Temp\_AI3C2B.tmp\Media.mst"
2013/3/5:23:09:59 liu LIU-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2013/3/5:23:09:59 liu LIU-PC Installing AutoCAD® 2012: TRANSFORMS="D:\x64\zh-cn\acad\acad.mst;C:\Users\liu\AppData\Local\Temp\_AI3C2B.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - Simplified Chinese\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/5:23:17:46 liu LIU-PC Install AutoCAD® 2012 Failed Installation aborted, Result=1603
2013/3/5:23:17:57 liu LIU-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2013/3/5:23:18:12 liu LIU-PC Rollback Autodesk Material Library 2012 Succeeded
2013/3/5:23:18:12 liu LIU-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/3/5:23:18:12 liu LIU-PC Rollback .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1619
全部回复(7 )
  • 我是独
    我是独 沙发
    我想问你解决没有 我也遇到同样的问题完全没办法
    2016-08-01 11:33:01
  • wonda123
    wonda123 板凳
    是不是你也遇到了这个问题,我想是不是系统的问题,缺少了什么文件之类的
    2013-03-09 22:50:09
CAD下载及教程
52.09 万条内容 · 690 人订阅
求大神交CAD诀窍
本人大学生一枚 希望有好心人发下 越详细越好 谢谢
