土木在线论坛 \ 建筑设计 \ CAD下载及教程 \ 求高手帮忙改下我写的这个插件
求高手帮忙改下我写的这个插件
发布于:2012-12-12 11:57:12 来自:建筑设计/CAD下载及教程 [复制转发]
请问如何把里面所用 字体样式 改成 华文细黑 啊?
; | 第 4 张 |
; | 版本: V1.1 作者: YC |
(defun C:D4(/ dx dy dx1 pt ptt lay)
(setvar "CMDECHO" 0)
(setq lay (getvar "clayer"))
(command "color" "bylayer")
(command "layer" "m" "D4" "c" "yellow" "D4" "")
(if (or (= nil (tblsearch "style" "TuHao"))
(/= (cdr (assoc 40 (tblsearch "style" "TuHao"))) 0)
(command "STYLE" "TuHao" "RC9,hztxt" "0" ".7" "0" "n" "n" "n")
(setq pt (getpoint "\nInsert point: "))
(command "text" "s" "TuHao" pt "3" "0" "第 4 张")
(setq dy (cadr pt))
(setq dx (car pt))
(setq dx1 (+ dx 9))
(setq dy (+ dy 0.5))
(setq ptt (list dx1 dy))
(setq RC91 (rtos RC9 2 0))
(command "text" "s" "TuHao" ptt "4" "0" RC91)
(command "layer" "s" lay "")
(princ)(princ)
  • gaoweists
    gaoweists 沙发
    你的这行是新建文字样式的命令,这样改
    (command "STYLE" "TuHao" "华文细黑" "0" ".7" "0" "n" "n" "n")
    其他的命令格式要正确。
    2013-04-05 14:31:05
CAD下载及教程
52.09 万条内容 · 690 人订阅
打印为什么参照无法显淡
打印的时候,布局里用参照,打印设置里显淡70,打印出来却没显淡,这是怎么回事啊?颜色设置都对的,我在布局里用PL线直接画,打印的时候,PL线显淡了,参照却没有
