土木在线论坛 \ 注册考试 \ 注册土木工程师 \ 请教:谁有整套砖混结构的计算书?
请教:谁有整套砖混结构的计算书?
发布于:2007-08-20 16:23:20 来自:注册考试/注册土木工程师 [复制转发]
小弟大学刚毕业 ,不熟计算步骤及方法,请指教!!
注册土木工程师
6.76 万条内容 · 269 人订阅
篇篇学之7:Hydroelectricity 2
The energy that may be extracted from water depends not only on the volume but on the difference in height between the water impoundment(or source) and the water outflow.This height difference is called the head.The amount of potential energy in water is directly proportional to the head.For this reason,it is advantageous to build dams as high as possible to produce the maximum electrical energy.The machanical power of falling water is an age-old tool.Of all the renewable energy sources that generate electricity,hydropower is the most often used.It is one of the oldest sources of energy .
