土木在线论坛 \ 站务休闲 \ 版主议事 \ 神龙,看到了请进来
神龙,看到了请进来
发布于:2007-08-19 19:53:19 来自:站务休闲/版主议事 [复制转发]
刚在水处理那边看到你的一个帖子,是ASTM标准。我找这个标准很久了。不过我要的你都没有。如果方便的帮我找到这几个,传给我。在这里先谢谢了!
F1504-02 Standard Specification for Folded Poly(Vinyl Chloride) (PVC) Pipe for Existing Sewer and Conduit Rehabilitation
F1697-02 Standard Specification for Poly(Vinyl Chloride) (PVC) Profile Strip for Machine Spiral-Wound Liner Pipe Rehabilitation of Existing Sewers and Conduits
F1698-02 Standard Practice for Installation of Poly(Vinyl Chloride)(PVC) Profile Strip Liner and Cementitious Grout for Rehabilitation of Existing Man-Entry Sewers and Conduits
F1735-02e1 Standard Specification for Poly (Vinyl Chloride) (PVC) Profile Strip for PVC Liners for Rehabilitation of Existing Man-Entry Sewers and Conduits
F1741-02a Standard Practice for Installation of Machine Spiral Wound Poly (Vinyl Chloride) (PVC) Liner Pipe for Rehabilitation of Existing Sewers and Conduits
F1743-96(2003) Standard Practice for Rehabilitation of Existing Pipelines and Conduits by Pulled-in-Place Installation of Cured-in-Place Thermosetting Resin Pipe (CIPP)
F1804-03 Standard Practice for Determining Allowable Tensile Load for Polyethylene (PE) Gas Pipe During Pull-In Installation
F1865-02a Standard Specification for Mechanical Cold Expansion Insert Fitting With Compression Sleeve for Cross-linked Polyethylene (PEX) Tubing
F1867-98 Standard Practice for Installation of Folded/Formed Poly (Vinyl Chloride) (PVC) Pipe Type A for Existing Sewer and Conduit Rehabilitation
F1871-02 Standard Specification for Folder/Formed Poly (Vinyl Chloride) Pipe Type A for Existing Sewer and Conduit Rehabilitation
F1947-04 Standard Practice for Installation of Folded Poly (Vinyl Chloride) (PVC) Pipe into Existing Sewers and Conduits
F2019-03 Standard Practice for Rehabilitation of Existing Pipelines and Conduits by the Pulled in Place Installation of Glass Reinforced Plastic (GRP) Cured-in-Place Thermosetting Resin Pipe (CIPP)
  • 空01
    空01 沙发
    你要什么,我可能可以帮你下到的!
    2007-08-21 14:54:21
  • heijindishi
    heijindishi 板凳
    http://gold.5wish.com/read.php?tid=8843&page=1&fpage=1
    找到了,但是我的威望不够,下不了
    2007-08-20 08:35:20
版主议事
8.49 万条内容 · 21 人订阅
可以群删了?
我今天在商吧里面看到了这个labixiaoxin006@co163哥们,帖子里面都是一些谢谢之类的话,申请群删并封id。
