土木在线论坛 \ 注册考试 \ 注册土木工程师 \ 篇篇学之6:Hydroelectricity
发布于:2007-08-16 23:05:16 来自:注册考试/注册土木工程师 [复制转发]
Hydroelectricity.orHydroelectric power,is a form of hydropower that uses the energy released as a result of water falling,or flowing downhill or by wave-differences,under the influence of gravity to produce electricity.Specifically,the mechanical energy of the flowing or waving water is converted to electrical energy by a water turbine generator.Hydroelectric power is usually generated at dams or other places where water descends from a height like coasts with a high tides difference.Hydroelectricity is a renewable energy source,since the water that flows in rivers has come from precipitation such as rain or snow and waves in the sea,or even ocean,are moon related.
WORDS:
Hydroelectricity 水电 release 释放 downhill 向下的 convert 转变
turbine generator 涡轮发电机 generate 产生(于) descend ...下来 tide 潮汐
precipitation 蒸发
全部回复(12 )
  • yolanda1977
    yolanda1977 沙发
    precipitation是降水或降水量的意思
    2007-11-07 09:17:07
  • xingshi2003jim
    wanna read the latest news or articles on hydroelectricity engineering :)
    2007-10-11 16:35:11
注册土木工程师
6.76 万条内容 · 269 人订阅
基础考试每日一题,希望大家参与
对管径沿程变化的管道( )A. 测压管水头线可以上升也可以下降B. 测压管水头线总是与总水头线相平行C. 测压管水头线沿程永远不会上升D. 测压管水头线不可能低于管轴线
