土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 触目惊心的照片,这样的柱子该怎么办???
在工地上遇到这样强悍的施工水准,我都不知道该怎么办了,请各位支支招...
全部回答(28 )
  • angieguo1977
    We also met the similar problem in Queensland Qustralia when we start to construct some bridges, our problem is due to problems of pouring concrete and grade concrete, Australian design is usually very tight to save every peny, so structure engineers’ responsibility become very heavy
    2007-09-25 22:04:25 来自 PC 评论 举报
  • yanash
    这样的施工队伍太不负责,迟早会出事儿的!
    这是什么工程,监理都干什么去了?难道这些问题监理都没发现?莫非是自家盖小楼,犯不上请监理……
    楼主贴图那个柱子都那样了,怎么拆模的时候没及时处理,要么趁强度没上来拆了重灌,要么就赶紧考虑加固处理!
    2007-08-26 10:42:26 来自 PC 评论 举报
140.16 万条内容 · 2207 人订阅
