土木在线论坛 \ 建筑设计 \ CAD下载及教程 \ 看看下面的程序到底有什么毛病
看看下面的程序到底有什么毛病
发布于:2007-08-11 09:27:11 来自:建筑设计/CAD下载及教程 [复制转发]
看看下面的程序到底有什么毛病,计算是正确的,就是运行的时候会发生错误
当文字的基准点位中间(只要不是左)就不能正常运行~
(DEFUN C:ttq ( / count ent gop next pt_base pt_new temp1 temp2 temp3 total yesno)
(setvar "OSMODE" 0)
(SETQ ENT (ENTSEL "\n 选择参照单行文本"))
(IF (= ENT NIL)
(PRINC "\n 没有选中物体")
(PROGN
(SETQ ENT (ENTGET (CAR ENT)))
(IF (/= (CDR (ASSOC 0 ENT)) "TEXT")
(PRINC "\n 选中的物体不是单行文本")
(PROGN
(INITGET 128 "X Y")
(SETQ YESNO (GETKWORD "\n 参照字的X轴(X) / 参照字的Y轴(Y):(X) "))
(IF (OR (= YESNO "X") (= YESNO NIL))
(SETQ PT_BASE (CADR (ASSOC 10 ENT)))
(SETQ PT_BASE (CAR (CDDR (ASSOC 10 ENT))))
(PRINC "\n 选择对齐的文本")
(SETQ GOP (ssget ":L")
COUNT 0
TOTAL 0
(REPEAT (SSLENGTH GOP)
(SETQ NEXT (ENTGET (SSNAME GOP COUNT)))
(IF (= (CDR (ASSOC 0 NEXT)) "TEXT")
(PROGN (SETQ TEMP1 (CAR (CDR (ASSOC 10 NEXT)))
TEMP2 (CADR (CDR (ASSOC 10 NEXT)))
TEMP3 (CAR (CDDR (CDR (ASSOC 10 NEXT))))
(SETQ PT_NEW (LIST PT_BASE TEMP2 TEMP3))
(SETQ PT_NEW (LIST TEMP1 PT_BASE TEMP3))
(SETQ
NEXT (SUBST (CONS 10 PT_NEW) (ASSOC 10 NEXT) NEXT)
(ENTMOD NEXT)
;(PRINC NEXT)
(SETQ TOTAL (1+ TOTAL))
(SETQ COUNT (1+ COUNT))
(PRINC "\n 共 ")
(PRINC TOTAL)
(PRINC "字体改变")
(PRINC)
  • 小萝卜的头
    (princ "\n>>>请输入wq,TEXT文本对齐.<<<")
    (defun c:wq (/ DATA1 DATA2 DQ1 DQ2 ENT1 ENT2 HV I
    P P1 P1X P1Y P2 P2X P2Y SS VAL0
    (if (and
    (setq ent1 (car (entsel "\n>>>对齐的目标文本<退出>:")))
    (setq data1 (entget ent1)
    val0 (cdr (assoc 0 data1))
    p1 (cdr (assoc 10 data1))
    p1x (car p1)
    p1y (cadr p1)
    (= val0 "TEXT")
    (progn
    (initget "h v")
    (setq hv (getkword "\n>>>水平对齐[h]或竖向对齐[v]<默认竖向v>:"))
    (if (= hv nil)
    (setq hv "v")
    (princ "\n>>>选择欲对齐的文本:")
    (if (setq ss (ssget ’((0 . "TEXT")))
    i 0
    (progn
    (repeat (sslength ss)
    (setq ent2 (ssname ss i)
    data2 (entget ent2)
    p2 (cdr (assoc ’10 data2))
    p2x (car p2)
    p2y (cadr p2)
    i (+ i 1)
    (cond ((= hv "v") (setq p (list p1x p2y)))
    ((= hv "h") (setq p (list p2x p1y)))
    (setq data2 (subst (cons 72 0) (assoc ’72 data2) data2)
    data2 (subst (cons 73 0) (assoc ’73 data2) data2)
    data2 (subst (cons 10 p) (assoc ’10 data2) data2)
    (entmod data2)
    (princ)
    http://acad.net.cn/viewthread.php?tid=340&extra=page%3D1
    来这里好看些,代码比较好看
    2007-08-11 14:19:11
  • 小萝卜的头
    ;;;这句可以改一下.用car cdr cadr cddr 太累人了.
    (setq val10 (cdr (ASSOC 10 NEXT))
    px (nth 0 val10)
    py (nth 1 val10)
    pz (nth 2 val10)
    ;;;这个我以前自己写过一个,扔了....
    ;;;建议:
    ;;;既然(只要不是左)就不能正常运行.
    ;;;那你就把全改左..可以研究一下TEXT的dxf组码
    2007-08-11 13:49:11
CAD下载及教程
52.09 万条内容 · 690 人订阅
四层办公楼的第四层做成轻钢屋架 行不行
四层办公楼的第四层做成轻钢屋架,房屋建筑宽度是13.08M,在规范上有十二米的屋架 请问该怎么做,新手请教!!!
