土木在线论坛 \ 电气工程 \ 供配电技术 \ 如何设计一个电磁场方向的实验啊?
我看了许多书,但却不知道怎样,这个电磁场实验还要求有一定的可行性啊。请教各位大虾!!!!
全部回答(4 )
  • yijianmei
    楼主真好学啊!
    我介绍一点东西给你,希望有用。
    ANTENNA THEORY AND APPLICATIONS
    CAD formula for patches with corner cut-dual mode filter and CP microstrip antenna
    …………SUN Yu-xuan Y. L. CHOW FANG Da-gang(557)
    A new direction finding algorithm based fractional order moment
    ………Lu Ze-jun XIAO Xian-ci (561)
    An aperture-coupled microstrip patch antenna without surface wave loss
    ………CHENG Chong-hu K. Li K. F. Tong et al.(565)
    CIR performance analysis of a dynamic multi-layer cellular co nfiguration
    ………Zhang Zu-fan Du Hui-ping(569)
    The loaded normal mode helical antenna
    ………JI Yi-cai GUO Jing-li LIU Qi-zhong(573)
    Analysis of a round strip antenna using the finite-difference time-domain method
    ………LI Tai-quan TIAN Mao WU Qing-lin et al.(577)
    Optimization design of E-plane branch-waveguide couplers using genetic algorithms
    ………WANG Xiao-lu LI Lei WANG Qun-jie(581)
    ELECTROMAGNETIC THEORY AND APPLICATIONS
    Unconditionally stable 2-D ADIFDTD method in perfectly matched uniaxial medium
    ………ZHAO Yan-wen NIE Zai-ping(586)
    A method of estimation for the amplitude-phase characteristics of HF-radar’s array-channels………TIAN Jian-sheng YANG Zi-jie GAO Huo-tao et al.(590)
    A real-time processing technique for on-board image based on wavelet transform
    ……… GUI Yan-ning JAO Li-cheng ZHANG Fu-shun(595)
    Application of DBF technique to FMICW radar
    ………CHENG Feng KE Heng-yu WEN Bi-yang et al.(599)
    Analytical expression of equivalent currents on stratified anisotropic material backed by metal surface………GUO Hui-ping LIU Xue-guan YIN Hong-cheng et al.(604)
    The approach of 3D terrain following in the terrain navigation
    ………WANG Guang-jun CHEN Xin TIAN Jin-wen et al.(609)
    RADIO PROPAGATION AND APPLICATIONS
    The optimization of quaternary chaotic spreading sequences and system simulation
    ………ZHANG Qi ZHENG Jun-li SUN Shou-yu(614)
    Seasonal variations of the vertical equivalent winds over Wuhan
    ………LUAN Xiao-li LIU Li-bo LEI Jiu-hou et al.(620)
    The rejection of hermitian image based on DDC…………E Guang-xi GONG Yao-huan(625)
    A new channel estimator with the aid of pilot symbols for a OFDM system
    ………SHAO Huai-zong PENG Qi-cong LI Yu-bai(628)
    A hybrid TDOA/AOA location algorithm and its performance analysis
    ………DENG Ping LI Li FAN Ping-zhi(633)
    A FH sequence based on a specified chaotic map
    ………DENG Hong-min HE Song-bai YU Jue-bang(637)
    A general conversion model of China rainfall rate distributions with different integration times………LIN Le-ke ZHAO Zhen-wei LIU Yu-mei(641)
    Response of ionospheric phase delay to LEO’s orbit biases in radio occultation methodology………JIANG Hu HUANG Cheng(646)
    Atmospheric radio noise characteristics at Fujian regions
    ………HUANG De-yao WANG Jiu-jie YANG Wei-fu et al.(650)
    FPGA realization of the HF chaotic frequency-hopping code
    ………CHEN Chun GAN Liang-cai(656)
    Implementation of GPS twin antennas real-time attitude determination system
    based on DSP………YANG Tie-jun ZHANG Xiao-ling FU Yu-sheng et al.(661)
    Performance of 3 dimension Turbo product code near Turbo convoluted code
    ………ZHANG Shen-ru DENG Xiao-yan(666)
    ELECTROMAGNETIC COMPATIBILITY AND APPLICATIONS
    The condition of "electrically small" concept on EMI testing in GTEM chamber
    ………XUE Qian-zhong CHEN Zhi-yu(670)
    Transient analysis of impedance of multiple conductor transmission lines above a lossy ground………ZHAO Zhi-bin LU Tie-bing CUI Xiang et al.(674)
    Radio interference analysis from multi-circuits AC hi
    2004-10-25 10:37:25 来自 PC 评论 举报
  • 欧零圈
    my god
    啥意思啊
    不懂
    太高深了
    2004-10-25 08:50:25 来自 PC 评论 举报
97.93 万条内容 · 2230 人订阅
