土木在线论坛 \ 环保工程 \ 水处理 \ 污水处理厂的升级改造
污水处理厂的升级改造
发布于:2007-08-04 22:49:04 来自:环保工程/水处理 [复制转发]
传统生化处理只能除去污水固体悬浮污染物,对氮磷等化学污染物无能为力,造成氮磷污染无法有效控制,致使全国几大内湖的富营养化(过氧化)仍在加剧,太湖已经告急,国家已经准备在老污水厂的升级改造上下很大的功夫,作为一个专业的环保公司,我们也在致力于这方面的研究与开发,我们新的技术已经通过了考验,现在正在首都机场污水处理厂投入建设,对原有的老厂进行改造,出水达到北京市一级标准。
我公司的核心技术----ICBR(internal circulation bio-reactor),将缺氧和好氧集于一体,具有有机负荷高,停留时间短,占地面积小,去除率高的特点,脱氮率可以达到90%以上,除磷工艺在此基础上增加厌氧,厌氧段采用公司研发的ICABR工艺,很好的去除水中的磷。非常适用于老污水厂的改造以及新污水厂的脱氮除磷。
联系方式:北京中航空港建设工程有限公司
电话:010-89553036
89553039
13601382289
联系人:韩先生
阴女士
  • xiaoyu188
    xiaoyu188 沙发
    我们现在有一项成熟的技术,可以快速提升现有活性污泥系统的能力(COD和氨氮)和稳定性, 可用于1B到1A的改造。该技术安装和维护可以在不停车的情况下进行。有愿意合作,请电邮到wastewater@live.cn,留下公司名称和联系方式。
    The Apex System, added to existing activated sludge systems, increases the effective Mixed Liquor Suspended Solids (MLSS) inventory of the system without increasing solids loading to the clarifier. This economical, easy-to-install system upgrades a wastewater treatment facility without increasing tankage. The Apex system requires no additional maintenance and installs with little or no disruption to plant operations.
    Increased Capacity
    The flexible, high-surface-area media is submerged in the activated sludge tanks to provide extensive surface area for biomass growth. The attached biomass population can increase the effective MLSS concentration by over 3000-4000 mg/l, increasing organic load capacity. This also reduces F/M ratios, improving process control and stability
    Higher MLSS Without Higher Clarifier Solids Loading
    Because a significant portion of the active biomass remains attached to the Apex rather than suspended in the mixed liquor, organic removal increases without overloading secondary clarifiers with higher solids loads. For activated sludge systems with clarifier solids loading problems, treatment performance can be maintained or even improved while reducing MLSS loading to the secondary clarifier.
    Resistant to Organic and Hydraulic Shock Loads
    An “Achilles Heel” of activated sludge technology is the potential for peak hydraulic surges to “wash out” the suspended biomass from the aeration basins. With Apex, a significant amount of biomass is fixed in place and is available to treat the incoming organic load that accompanies hydraulic surges
    Enhanced Nitrification
    The biomass living on the Apex media increases MCRT (Sludge Age), promoting nitrification. During cold weather and where lower compliance limits are imposed, the added biomass improves the performance of nitrifying plants, or even allows non-nitrifying plants to nitrify.
    Active Media Surface
    Apex media has a tensile strength in excess of 1000 lbs. per lineal foot, yet is flexible enough to move like “reeds in a stream.” This movement creates localized turbulence that constantly renews surface areas and promotes oxygen transfer.
    The total surface area available for biomass attachment at startup is up to 800 sq. ft. per cubic foot of installed media module. However, dry surface area does not tell the whole story. From those 800 sq. ft. of attachment points, the biomass grows underwater in 3 dimensions, creating flexible “branches” of non-blinding active surface area that can be measured in pounds per cubic foot, while still allowing for free flow of oxygenated wastewater through the media.
    Economical
    By improving wastewater treatment without adding aeration tankage or clarifiers, the Apex System is a low-cost solution to upgrading activated sludge plants.
    Easy to Install
    The entire Apex system can be installed without dewatering the aeration basin or modifying the aeration diffusers. The custom-sized/constructed Apex modules are lowered into the aeration basin with a crane and supported by the tank walls or on legs above the tank floor.
    Durable and Long-Lasting
    Apex is designed for durability and long life under the harsh conditions of an activated sludge aeration tank. The Apex media uses high-strength polyester. Even if a strand is cut or broken, the fabric will not fray or unravel.
    2008-01-30 16:09:30
水处理
42.38 万条内容 · 1445 人订阅
求助:酒精废水
某酒精生产企业用小麦做原料,因提取小麦植物蛋白需要,将小麦磨的极细,导致后续原糟液用卧螺机分离时酒糟分离率低,酒糟蛋白含量底,直接降低了酒糟的商品价值,并且分离后的清夜中含有大量营养成分,SS较高,COD80000左右,如何才能二次分离清夜中的胶体,提高酒糟的饲料价值,降低SS
