土木在线论坛 \ 建筑设计 \ CAD下载及教程 \ lisp
lisp
发布于:2004-10-20 16:21:20 来自:建筑设计/CAD下载及教程 [复制转发]
我学lisp刚入门!!!
有谁会Autolisp编程!!
问:用简单的方法,在屏幕上绘制一个矩形表格,要求表格的行数,列数,起点,行距,列距,由用户自己输入!!
  • lzfat
    lzfat 沙发
    很简单的,你参照几个程序你就会编一些简单的lisp程序了
    2004-10-22 09:13:22
  • xcajcj
    xcajcj 板凳
    这是前几天在晓东CAD (http://www.xdcad.net) 上看见的,仅供你参考。
    ;;lisp制表程序
    (defun c:hzbg()
    (setvar "cmdecho" 0)
    (setq os (getvar "osmode"))
    (setvar "osmode" 0)
    (setq pt1 (getpoint "\n第一角点: "))
    (setq pt3 (getcorner pt1 "\n另一角点: "))
    (command "rectang" "w" 1 pt1 pt3)
    (setq wnn (1+ (getint "\n栏数 ||| <5>: ")))
    (if (null wnn) (setq wnn 5))
    (setq hnn (1+ (getint "\n行数 --- <5>: ")))
    (if (null hnn) (setq hnn 5))
    (setq pt2 (list (car pt3) (cadr pt1)))
    (setq pt4 (list (car pt1) (cadr pt3)))
    (setq ang (angle pt1 pt3))
    (cond ((and (> ang 0) (< ang (/ pi 2))) (setq pp1 pt1 pp2 pt2 pp3 pt3 pp4 pt4))
    ((and (> ang (/ pi 2)) (< ang pi)) (setq pp1 pt2 pp2 pt1 pp3 pt4 pp4 pt3))
    ((and (> ang pi) (< ang (* pi 1.5))) (setq pp1 pt3 pp2 pt4 pp3 pt1 pp4 pt2))
    ((and (> ang (* pi 1.5)) (< ang (* pi 2))) (setq pp1 pt4 pp2 pt3 pp3 pt2 pp4 pt1))
    (setq num 1 txt 65)
    (setq ww (distance pp1 pp2))
    (setq hh (distance pp1 pp4))
    (setq pt1 pp4 ppbas pp4 key 1)
    (repeat hnn
    (setq pt1 (polar pt1 (* pi 1.5) (/ hh hnn)))
    (setq pt2 (polar pt1 0 ww))
    (command "line" pt1 pt2 "")
    (if (> key 1)
    (progn
    (setq txtins (inters ppbas (polar pt1 0 (/ ww wnn)) pt1 (polar ppbas 0 (/ ww wnn))))
    (command "text" "m" txtins (/ hh hnn 2) 0 (itoa num))
    (setq num (1+ num))
    (setq ppbas pt1 key (1+ key))
    (repeat wnn
    (setq pt1 (polar pt1 0 (/ ww wnn)))
    (setq pt2 (polar pt1 (* pi 1.5) hh))
    (if (> key 1)
    (progn
    (setq txtins (inters ppbas (polar pt1 (* pi 1.5) (/ hh hnn)) pt1 (polar ppbas (* pi 1.5) (/ hh hnn))))
    (command "text" "m" txtins (/ hh hnn 2) 0 (chr txt))
    (setq txt (1+ txt))
    (prin1)
    2004-10-20 23:05:20
CAD下载及教程
52.09 万条内容 · 690 人订阅
工程量计算中的负桩号问题
张工: 您好!上次您到昆明院演示时说最新版的zdm2004解决了负桩号计算问题,但我的同事(商工)在计算时好像还是出现了无法辨明负桩号的情况:会把 0 -10.000认作10.000,试了几次都不行!难道和选用的字型有关吗? 打搅您了!
