土木在线论坛 \ 建筑结构 \ ANSYS \ ansys问题
ansys问题
发布于:2012-11-14 09:50:14 来自:建筑结构/ANSYS [复制转发]
我的模型出现这样的错误:
*** WARNING *** CP = 24124.500 TIME= 03:47:36
Contact element 109064 (real ID 13) status changes abruptly from
contact (with target element 108027) -> no-contact.
*** WARNING *** CP = 28775.906 TIME= 05:27:33
Contact element 108998 (real ID 13) status changes abruptly from
contact (with target element 108112) -> no-contact.
*** WARNING *** CP = 35595.109 TIME= 07:49:22
Contact element 119926 (real ID 16) status changes abruptly from
contact (with target element 119925) -> no-contact.
*** ERROR *** CP = 35595.125 TIME= 07:49:22
One or more elements have become highly distorted. Excessive
distortion of elements is usually a symptom indicating the need for
corrective action elsewhere. Try incrementing the load more slowly
(increase the number of substeps or decrease the time step size). You
may need to improve your mesh to obtain elements with better aspect
ratios. Also consider the behavior of materials, contact pairs,
and/or constraint equations. If this message appears in the first
iteration of first substep, be sure to perform element shape checking.
然后我点proceed,竟然还可以继续算,这是怎么回事????请教高手指导!谢谢!!!
  • xiaolizi0913
    xiaolizi0913 沙发
    路过,看看,顶一下。
    2014-03-24 21:35:24
  • lyl0703
    lyl0703 板凳
    楼主 我现在也出现了下面那个error 请问 你解决了吗?能否告知相关解决办法啊
    2013-11-25 16:33:25
ANSYS
4.39 万条内容 · 152 人订阅
架空线分裂导线命令流解惑!!急
*do,i,-41,43,1k,i+42+10100,0.225,(i-1)*5+210,3281*(exp((i-1)*5/3281)+exp(-(i-1)*5/3281))/2-3281+31.5-5*enddo*do,j,10101,10184,1l,j,j+1latt,1,1,1,,,lesize,all,,,1lmesh,alllsel,u,,,all *enddo 第二行字体是什么意思?主要是最后面的+31.5-5是怎么来的,求高手解答!!!
