土木在线论坛 \ 建筑结构 \ ETABS \ ETABS运行分析报错,请高手帮助。
ETABS运行分析报错,请高手帮助。
发布于:2012-10-31 12:54:31 来自:建筑结构/ETABS [复制转发]
* * * W A R N I N G * * *
THE SOLUTION LOST 7.4 DIGITS OF ACCURACY FOR DOF UZ OF JOINT 5782
LOCATED AT X = 17.100000, Y = 5.400000, Z = 5.450000,
STIFFNESS MATRIX DIAGONAL VALUE = 20575.287
NEGATIVE STIFFNESS FOUND DURING SOLUTION FOR DOF U2 OF CONSTRAINT 15
LOCATED AT X = 10.831962, Y = 5.413593, Z = 19.950000,
STIFFNESS MATRIX DIAGONAL VALUE = -8.1309E+06,
NEGATIVE STIFFNESS FOUND DURING SOLUTION FOR DOF U1 OF CONSTRAINT 16
LOCATED AT X = 10.831962, Y = 5.413593, Z = 17.050000,
STIFFNESS MATRIX DIAGONAL VALUE = -4.5792E+06,
THE STRUCTURE IS UNSTABLE OR ILL-CONDITIONED !!
CHECK THE STRUCTURE CAREFULLY FOR:
- INADEQUATE SUPPORT CONDITIONS, OR
- ONE OR MORE INTERNAL MECHANISMS, OR
- ZERO OR NEGATIVE STIFFNESS PROPERTIES, OR
- EXTREMELY LARGE STIFFNESS PROPERTIES, OR
- BUCKLING UNDER P-DELTA LOADS (IF ANY), OR
- AN EIGEN SHIFT (IF ANY) ONTO A NATURAL FREQUENCY
弹出 Unable to complete operation 'RunAnalysis'!
  • wilei
    wilei 沙发
    遇到同样的问题了
    不过之前我没导入荷载组合,刚刚改了现在再试算一次
    2012-12-11 10:00:11
ETABS
1.67 万条内容 · 53 人订阅
ETABS2012新版本
论文简介: 2012新版本介绍,介绍了主要新增功能,界面接口及抗震性能设计方法 附件名:201209271348755901281.pdf 文件大小:4165K (升级VIP 如何赚取土木币)
