土木在线论坛 \ 人才招聘 \ 学生专栏 \ 求与园林制图相关的资料
求与园林制图相关的资料
发布于:2007-06-05 20:05:05 来自:人才招聘/学生专栏 [复制转发]
我是一名刚刚与园林制图接触的在校学生
感觉在园林制图与美术方面学习比较吃力
现在刚刚接触制图
我想寻找一些与制图相关的资料和软件
最好是适合初学者的
所以资料力求简单明了
目前教材方面的书籍感觉说的不是很明白
很含糊的样子
所以很是希望各到大家的帮助
在此只能说一句谢谢了
全部回复(3 )
学生专栏
23.9 万条内容 · 138 人订阅
谁帮我翻译一下啊!
我毕业设计要的,那个帮我翻译一下啊!文章是美国土木工程学会的,跪求翻译! Behavior of Rigid-Soft Particle MixturesJong-Sub Lee, Jake Dodds, and J. Carlos Santamarina,Abstract: Mixtures of rigid sand particles and soft fine-grained rubber particles are tested to investigate their small and large-strain responses. Mixtures are prepared with different volumetric sand fraction sf to identify the transition from a rigid to a soft granular skeleton using wave propagation, k0 loading, and triaxial testing. Deformation moduli at small, middle, and large strains do not change linearly with the volume fraction of rigid particles; instead, deformation moduli increase dramatically when the sand fraction exceeds a threshold value between sf=0.6 — 0.8 that marks the formation of a percolating network of stiff particles. The friction angle increases with the volume fraction of rigid particles. Conversely, the axial strain at peak strength increases with the content of soft particles, and no apparent peak strength is observed in specimens with low sand fraction (sf0.6). The presence of soft particles alters the formation of force chains. Although soft particles are not part of high-load carrying chains, they play the important role of preventing the buckling of stiff particle chains.
