土木在线论坛 \ 环保工程 \ 水处理 \ 推荐一种新型进口重金属去除剂:高效重金属去除剂(EMRA)
发布于:2012-09-25 11:48:25 来自:环保工程/水处理 [复制转发]
高效重金属去除剂(EMRA)说明书
High efficiency of heavy metal removal agents ( EMRA )
一、 简介与特性
One, introduction and characteristics
高效重金属去除剂EMRA是一种专门针对金属废水的一种含有羟基、羧基、醛基及多功能团的化合物。与重金属废水反应,适用于铜、镍、锌、铅、镉、三价铬等多金属,具有反应迅速、重金属去除率高、投药量小、反应条件温和的特性。
Efficient removal of heavy metal from agent EMRA is a specific metal wastewater containing hydroxyl, carboxyl, aldehyde and multiple functional group compounds. With the heavy metal wastewater, applied to copper, nickel, zinc, lead, cadmium, chromium and other metals, has rapid response, heavy metal removal rate is high, small dosage, mild reaction conditions and characteristics.
二、 技术指标
Two, technical indicators
项 目
Item 指 标
Index
外 观External view 淡红色溶液Light red solution
有效基质含量 % ≥
Effective matrix content% > 90
PH 7-9
密度(25℃)g/cm3 ≥
Density (25℃)g/cm3 ≥ 1.36
毒性Toxicity 无毒、无刺激性气味
Non-toxic, non-irritating smell
三、使用方法
Three, the use of methods
一般使用前需要先将20倍浓缩液进行稀释,稀释成1%-2.5%,然后把稀释好的药剂加到含重金属的废水中,充分搅拌,立即就会出现絮状泥渣,为加速沉淀,可以适量补加铝盐,加速泥渣成渣。一般加药量与废水中金属离子浓度成正比,实验室数据,20mg/l(或10PPM)的金属离子浓度,加入2%的药剂1ml,基本总金属离子浓度都低于0.1mg/l(或0.1PPM),超过国家一级金属离子浓度的达标要求。
In general use before 20 times concentrated solution is diluted, diluted to 1%-2.5%, and then diluting the good medicine to heavy metal containing wastewater, stirring, immediate flocculent sludge, in order to accelerate the precipitation, the amount can be added with aluminum salt, accelerated sludge slagging. General dosage and concentration of metal ions in wastewater by proportional, laboratory data, 20mg/l ( or 10PPM ) of the metal ion concentration, adding 2%. 1ml, basic general metal ion concentration is lower than 0.1mg/l ( or 0.1PPM ), more than the national level the standard requirements of metal ion concentration.
所加药剂的量,根据废水中含有重金属离子的浓度来确定,金属离子浓度高,所需要加的药剂量大,反之也成立。一般处理一吨废水的成本约1-4.5元每吨。
The addition of chemicals according to the amount of waste water containing heavy metal ions, the concentration of metal ion concentration, high, with the required large doses, and vice versa. General treatment of one ton of waste water costs about 1-4.5 yuan per ton.
四、 包装与贮存
Four, packing and storage
高效重金属去除剂EMRA采用塑料桶包装,每桶20kg,20倍浓缩液或标准液。贮存远离重金属盐、还原性物质,注意被污染,贮存期为十二个月。
High efficiency of heavy metal removal agent EMRA packaging plastic barrels, a barrel of 20kg, 20 times concentrated liquid or standard solution. Store away from heavy metal salts, reductive substances, attention is pollution, storage period of twelve months.
五、 安全与防护
Five, security and protection
高效重金属去除剂EMRA,带微碱性,操作时注意劳动保护,稀释溶药过程中佩戴劳动防护品,应避免与皮肤、眼睛等接触,接触后用大量清水冲洗。
Efficient removal of heavy metal from agent EMRA, with a slightly alkaline, operation attention to labor protection, dilution medicine dissolving the wearer during labor protection products, should be avoided with the skin, eye contact, contact after rinse with plenty of water.
  • gyyongchao
    gyyongchao 沙发
    你们这个药剂对磷酸和硫酸的混合液中的金属离子的去除有用吗?
    2013-03-30 14:23:30
水处理
43.46 万条内容 · 1516 人订阅
造纸行业的污染净化之路如何才能走得更好?
众所周知,造纸行业中所产生的污染量是很大的,加上其中的有害物质很难处理,因此给我们的生活造成了严重的威胁,这个时候我们就来看看如何使用适当的过滤器设备对其进行处理吧。  目前,我国的造纸业面临着落后产能淘汰,废纸、非木纤维原料的质量管理、污染控制的严峻局面,在“林浆纸一体化”在中国如何取得经济和社会效益双赢等问题仍然需要全行业的认真应对。在原料、环保双重压力下,行业发展并不乐观。  国家对造纸行业严格细化的淘汰、准入标准和措施,都在鼓励现代化发展方向,同时,给产品质量好、污染排放少、资源利用充分的先进企业提供了发展的空间。全自动高效过滤器真正的转变了我国传统的造纸观念,使我国的造纸行业能够有更好的发展。在我国绿色经济的发展中,全自动高效过滤器一直都领跑着前进的脚步。
