土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 谁能说说23500高的圆柱骨架怎么做
说明:只有地面和顶子是混凝土的
圆柱外铝塑板干挂
全部回答(4 )
  • dennismmm
    such high column is hard to design and construction. in terms of construction, I woud like to suggest you to use composite column ie steel tube with RC inside. the column may be designed as gravity only. in seismic area, the deformation compatibilty shall be satisfied in accordance with UBC
    Regards
    Dennis
    2008-08-22 21:25:22 来自 PC 评论 举报
  • 天柱
    柱直径是多少?
    2008-08-17 08:21:17 来自 PC 评论 举报
140.17 万条内容 · 2232 人订阅
