土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 竖向荷载出错,可是看不懂。。。
竖向荷载出错,可是看不懂。。。
发布于:2007-04-26 16:58:26 来自:建筑结构/混凝土结构 [复制转发]
在设计院做毕业设计,在SATWE数据检查时出现错误,具体情况:
*** Report of Data Checking ***
| total information |
| section information |
| Geometry information |
***** Floor No. 1 *****
| total information of floor |
| node information |
| beam information |
| column information |
| other information |
***** Floor No. 2 *****
| node information |
| beam information |
| other information |
***** Floor No. 3 *****
| node information |
| beam information |
| other information |
| vertical load information |
Floor No. 1 Nload = 1118
ERROR 1011 : X4 < X3 or X3+X4 > Lb, No = 537 Lb = 1.86
ERROR 1011 : X4 < X3 or X3+X4 > Lb, No = 552 Lb = 3.90
Floor No. 2 Nload = 1118
Floor No. 3 Nload = 455
ERROR 1011 : X4 < X3 or X3+X4 > Lb, No = 226 Lb = 4.00
ERROR 1011 : X4 < X3 or X3+X4 > Lb, No = 407 Lb = 2.08
| wind load information |
Floor No. 1 Ntw = 1 Njw = 0
Floor No. 2 Ntw = 1 Njw = 0
Floor No. 3 Ntw = 1 Njw = 0
小弟不懂到底是些什么东西,望各位前辈点播一二,谢谢!
全部回复(14 )
  • hrs97616
    hrs97616 沙发
    是三角形荷载、梯形荷载,在你输入的时候其实你把该线荷载的范围放大了,通俗一点呢就是你的线荷载的长度已经超过了你所要指定的那一个网格的长度
    2007-09-28 19:37:28
  • yudy2828
    yudy2828 板凳
    我的也出现了这个问题
    第一次是只有几何数据错误
    | node information |
    | beam information |
    Warn 76 : Lb < 0.2, Nb= 23 Lb= 0.03
    Warn 76 : Lb < 0.2, Nb= 145 Lb= 0.11
    Warn 76 : Lb < 0.2, Nb= 154 Lb= 0.15
    | shear-wall information |
    | other information |
    WARN 110 : 该梁为悬臂梁,请进行校核, Nb= 200
    WARN 110 : 该梁为悬臂梁,请进行校核, Nb= 222
    WARN 110 : 该梁为悬臂梁,请进行校核, Nb= 285
    后来去该了下出问题的梁再检查,但原来的问题没解决,又多了个竖向荷载的错误
    Floor No. 1 Nload = 31
    Floor No. 2 Nload = 197
    ERROR 1011 : X4 < X3 or X3+X4 > Lb, No = 197 Lb = 8.21
    Floor No. 3 Nload = 188
    Floor No. 4 Nload = 192
    Floor No. 5 Nload = 151
    Floor No. 6 Nload = 75
    Floor No. 7 Nload = 73
    Floor No. 8 Nload = 73
    Floor No. 9 Nload = 73
    Floor No. 10 Nload = 73
    Floor No. 11 Nload = 73
    Floor No. 12 Nload = 73
    Floor No. 13 Nload = 73
    Floor No. 14 Nload = 73
    Floor No. 15 Nload = 73
    Floor No. 16 Nload = 76
    Floor No. 17 Nload = 91
    Floor No. 18 Nload = 91
    Floor No. 19 Nload = 26
    Floor No. 20 Nload = 0
    2007-05-23 00:51:23
140.21 万条内容 · 2160 人订阅
有什么好的结构群,想加入啊!
有没有同是做结构的,小妹想加入结构群啊!刚出来做设计不久,有很多问题想请教
