土木在线论坛 \ 建筑设计 \ CAD下载及教程 \ 求助:lisp定义命令
:请教我用lsp文件做一个命令,按所选颜色来移动对象,我的意思是说在同一个图层里有多种颜色的情况下,请尽量用简单的程序,详细的说明,谢谢,还有能不能告诉我一个自学auto lisp 语言的网站,
全部回答(2 )
  • shuibobo
    auto cad 中加载的lisp程序怎么改小数点后的位数呢?
    有一个标坐标值(x,y)的lisp程序,但是小数点后小数位数是4位,怎样改成2位呢?多谢指教。请直接把源代码写下来哦,并表明更改的位置。
    (DEFUN WIDSET()
    (INITGET 1 "Y N")
    (SETQ IDSET1 (GETKWORD "\n是否标注编号? <Y or N>"))
    (INITGET 1 "Y N")
    (setq idset2 (getkword "\n是否标竖向?<Y or N>"))
    (INITGET 1 "Y N")
    (setq idset3 (getkword "\n是否固定标注线角度?<Y or N>"))
    (INITGET 1 "Y N")
    (setq bname (strcat "xy" idset1 idset2))
    (setq b (getint "\n图纸比例?"))
    (setq w (getreal "\n标注框的宽度<cm>?"))
    (setq sca (/ (* w b ) 1000))
    (if (= idset1 "Y")
    (setq bh00 (getstring "\n第一交*点的编号"))
    (PRINC)
    (DEFUN C:WID()
    (if (null sca)
    (WIDSET)
    (princ "\n欢迎使用道路坐标自动标注系统")
    (setvar "cmdecho" 0)
    (SETQ IDP(GETPOINT "\n选择标注点"))
    (setq oooo (getvar "osmode"))
    (setvar "osmode" 0)
    (SETQ PPP(GETPOINT "\n选择标注位置"))
    (setvar "osmode" oooo)
    (if (= idset1 "Y")
    (progn
    (princ "\n 请输入交*点编号:<")
    (princ bh00)
    (princ ">")
    (setq bh01 (getstring))
    (IF (/= bh01 "")
    (setq bh00 bh01)
    (princ)
    (SETQ A(*(/(ANGLE IDP PPP)PI)2))
    (SETQ C(FIX A))
    (SETQ ANG(*( (* 2 C)1)(/ pi 4.0)))
    (if (= idset3 "N")
    (setq dimp ppp)
    (SETQ DIMP(POLAR IDP ANG(DISTANCE IDP PPP)))
    (SETQ high (COND((= bname "xyNN")1.6)
    ( (= bname "xyYY")3.3)
    ( (= bname "xyNY")2.5)
    ( (= bname "xyYN")2.5)
    (setq dimpx (car dimp))
    (setq dimpy (cadr dimp))
    (if (or (= c 3) (= c 0) )
    (setq INSPx ( dimpx (* sca 5)))
    (setq INSPx (- dimpx (* sca 5)))
    (if (or (= c 0) (= c 1))
    (setq INSPy ( dimpy (* sca high )))
    (setq INSPy (- dimpy (* sca high)))
    (setq INSP (LIST INSPx INSPy))
    (SETQ M(CAR(TRANS IDP 1 0)))
    (SETQ N(CADR(TRANS IDP 1 0)))
    (SETQ X(RTOS M 2))
    (SETQ Y(RTOS N 2))
    (if (= idset2 "Y")
    (setq z (getstring "\输入标高"))
    (princ)
    (COMMAND"LINE""none"IDP"none"DIMP"")
    (cond ((= bname "xyNN")(COMMAND"INSERT" bname "none" INSP sca"""" Y X ))
    ((= bname "xyYN")(COMMAND"INSERT" bname "none" INSP sca"""" bh00 Y X ))
    ((= bname "xyNY")(COMMAND"INSERT" bname "none" INSP sca"""" Y X Z))
    ((= bname "xyYY")(COMMAND"INSERT" bname "none" INSP sca"""" bh00 Y X Z))
    (if (= idset1 "Y")
    (progn
    (setq bhlen (strlen bh00))
    (if (wcmatch bh00 "*##")
    (setq bh00 (strcat (substr bh00 1 (- bhlen 2)) (itoa ( 1 (atoi (substr bh00 (- bhlen 1) ))))))
    (setq bh00 (strcat (substr bh00 1 (- bhlen 1)) (chr( 1 (ascii(substr bh00 bhlen 1))))))
    (setvar "cmdecho" 1)
    (PRINC)
    2007-09-06 12:53:06 来自 PC 评论 举报
  • anaywa
    不知道符合你的要求不 ?
    http://www.pianyiba.com/product/697654/
    2007-04-24 09:20:24 来自 PC 评论 举报
CAD下载及教程
52.09 万条内容 · 690 人订阅
