结构资料库
返回版块41.29 万条内容 · 429 人订阅
Reliability of Frame and Shear Wall论文简介: Abstract: An efficient and accurate algorithm is developed to evaluate the reliability of a steel frame and reinforced concrete shear wall structural system subjected to static loading. In a companion paper, the algorithm is extended to consider dynamic loading, including seismic loading. The concept integrates the finite-element method and the first-order reliability method, leading to a stochastic finite element-based approach.
只看楼主 我来说两句 抢板凳
