土木在线论坛 \ 建筑结构 \ 结构资料库 \ Seismic earth pressures on rigid an
发布于:2007-04-10 17:21:10 来自:建筑结构/结构资料库 [复制转发]
论文简介:
Abstract
While limiting-equilibrium Mononobe–Okabe type solutions are still widely used in designing rigid gravity and flexible cantilever
retaining walls against earthquakes, elasticity-based solutions have been given a new impetus following the analytical work of Veletsos and
Younan [23]. The present paper develops a more general finite-element method of solution, the results of which are shown to be in agreement
with the available analytical results for the distribution of dynamic earth pressures on rigid and flexible walls. The method is then employed
to further investigate parametrically the effects of flexural wall rigidity and the rocking base compliance.
附件名:20074101176196916113.zip
文件大小:757K
(升级VIP 如何赚取土木币)
结构资料库
41.29 万条内容 · 428 人订阅
《砌体工程施工质量验收规范》
《砌体工程施工质量验收规范GB 50203-2002(含条文说明)》
