土木在线论坛 \ 人才招聘 \ 学生专栏 \ 想毕业工作后考结构师证
想毕业工作后考结构师证
发布于:2007-04-09 20:48:09 来自:人才招聘/学生专栏 [复制转发]
我是专科生,想毕业工作后先干施工,工作中考结构师证,考好后到设计院工作,我的这个想法可行吗?另外我将这个时间定为5年,大家觉得我5年能考的上吗?
  • yangg418
    yangg418 沙发
    世间最珍贵的不是‘得不到’和‘已失去’,而是现在能把握的幸福
    2007-09-17 20:48:17
  • jlkjguozhi
    jlkjguozhi 板凳
    与你自己的能力有关.
    2007-04-10 17:45:10
学生专栏
23.9 万条内容 · 138 人订阅
小弟,跪求下面的中文翻译!
A number of additional economical benefits stem from the use of CFTs. The tube serves as formwork in construction, which decreases labor and material costs. In moderate- to high-rise construction, the building can ascend more quickly than a comparable reinforced concrete structure since the steelwork can precede the concrete by several stories. The cost of the member itself is much less than steel and roughly equivalent to reinforced concrete on a strength per dollar basis for low to medium strength concrete (Webb, 1993). When compared to steel moment resisting frames, in unbraced CFT frames, the amount of savings in steel tends to grow as the number stories increases (Morino et al., 1996).On the other hand, relatively simple beam- to-column connection details can be utilized for rectangular CFT members. This also results in savings for the total cost of the structure and facilitates the design process. In addition, the steel tube and concrete act together to provide natural reinforcement for the panel zone, which reduces the material and labor costs of the connections. With the use of high-strength concrete, CFTs are stronger per square foot than conventional reinforced concrete columns (Webb, 1993).In high-strength applications, smaller column sizes may be used, increasing the amount of usable floor space in office buildings. The smaller and lighter framework places less of a load on the foundation, cutting costs again. These advantages have secured an expanding role for this versatile structural element in modern construction.
