电气资料库
返回版块70.19 万条内容 · 799 人订阅
基于EMTDC的HVDC极控制的建模与仿真论文简介: 为了配合高压直流输电系统在我国的发展,介绍了高压直流输电极控制系统的基本结构和工作原理,运用PSCAD/ EMTDC 仿真软件对极控系统中的最主要功能,如定电流控制、定电压控制、定熄弧角控制以及限幅环节进行了数字建模,并应用于Cigre 的HVDC 标准测试系统,对4 种工况进行仿真计算,仿真结果表明该极控系统具有良好的跟踪设定参考值变化的能力;当交、直流系统发生故障时,控制系统调节快速,能迅速抑制故障,并使故
全部回复(7 )
只看楼主 我来说两句-
zsxjob
沙发
非常感谢!!!
2012-01-31 08:56:31
lhb968
板凳
hgjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjj
2008-11-11 13:19:11
加载更多回复 举报
