土木在线论坛 \ 暖通空调 \ 暖通资料库 \ Measurementsofairchangerates__
发布于:2007-03-19 15:27:19 来自:暖通空调/暖通资料库 [复制转发]
论文简介:
这篇文章,是黄老师提供的,本人曾在网站上搜索好多次英语论文。服务大家方便,论文采用的测试方法也是值得学习的。
附件名:20073191174289254552.zip
文件大小:689K
(升级VIP 如何赚取土木币)
  • tumugongcheng2011
    谢谢楼主无私奉献!
    2011-03-25 13:07:25
  • zidai2004
    zidai2004 板凳
    由于第一次发,没注意到这个排版问题。因此现在把论文摘要回复下:
    Abstract
    This paper describes the measurements of the air change rates and air flow patterns in two large single-cell aircraft hangar buildings. The decay of the tracer gas sulfur hexafluoride was used to measure the air change rates. It was possible to achieve a uniform mixture of indoor
    air and the tracer gas in the hangars using the air circulation fans of the heating system. Stratified air layers characterized the air flow patterns within the hangars. For the test conditions, measured air change rates for the two hangars are in the range 0.32 to 0.47 air changes per hour. Results also suggest that five sampling locations at about 1.8 m (6 ft) height are sufficient to obtain a representative air change rate for large single-cell buildings. Crown Copyright 0 1997 Published by Elsevier Science S.A.
    Keywords: Field measurement; Air change rate; Air flow pattern; Large space industrial buildings; Aircraft hangars
    2007-03-19 15:45:19
暖通资料库
25.5 万条内容 · 720 人订阅
毕业设计说明书
论文简介: 某办公楼空调通风系统设计 附件名:20073191174280093199.zip 文件大小:1334K (升级VIP 如何赚取土木币)
