土木在线论坛 \ 电气工程 \ 电气资料库 \ ifix3.5教程4
ifix3.5教程4
发布于:2007-03-19 11:47:19 来自:电气工程/电气资料库 [复制转发]
iFIX_3.使用VBA和脚本: http://book.ifixonline.com/source/start_opt_using_vba_and_scri pting.htm
iFIX_调整脚本性能: http://book.ifixonline.com/source/start_opt_tuning_your_scri pting_performance.htm
iFIX_清理代码: http://book.ifixonline.com/source/start_opt_cleaning_your_code.htm
iFIX_从脚本中访问数据库: http://book.ifixonline.com/source/start_opt_accessing_the_database_from_scri pting.htm
iFIX_使用Fix32对象: http://book.ifixonline.com/source/start_opt_using_the_fix32_object.htm
iFIX_使用FindObject方法: http://book.ifixonline.com/source/start_opt_using_the_findobject_method.htm
iFIX_使用FixDataSystem对象: http://book.ifixonline.com/source/start_opt_using_the_fixdatasystem_object.htm
iFIX_访问动画对象: http://book.ifixonline.com/source/start_opt_accessing_animated_objects.htm
iFIX_在Initialize和Activate事件中编写代码: http://book.ifixonline.com/source/start_opt_placing_code_in_the_initialize_and_activate_events.htm
iFIX_使用iFIX子程序和专家: http://book.ifixonline.com/source/start_opt_using_ifix_subroutines_and_experts.htm
iFIX_使用调度程序: http://book.ifixonline.com/source/start_opt_working_with_the_scheduler.htm
iFIX_预处理调度: http://book.ifixonline.com/source/start_opt_resolving_schedules.htm
iFIX_运行调度: http://book.ifixonline.com/source/start_opt_running_schedules.htm
iFIX_使用命令包: http://book.ifixonline.com/source/start_opt_using_command_wrappers.htm
iFIX_使用单个定时器和事件对象: http://book.ifixonline.com/source/start_opt_using_a_single_timer_or_event_object.htm
iFIX_引用画面或全局页: http://book.ifixonline.com/source/start_opt_referencing_pictures_or_global_pages.htm
iFIX_用户全局变量: http://book.ifixonline.com/source/start_opt_user_globals.htm
iFIX_4.系统级优化: http://book.ifixonline.com/source/start_opt_system_wide_optimizations.htm
iFIX_升级硬件: http://book.ifixonline.com/source/start_opt_upgrading_your_hardware.htm
iFIX_安装加速卡: http://book.ifixonline.com/source/start_opt_installing_an_accelerator_card.htm
iFIX_整理硬盘碎片: http://book.ifixonline.com/source/start_opt_defragment_the_hard_disk.htm
iFIX_分布附加的应用程序: http://book.ifixonline.com/source/start_opt_distributing_additional_applications.htm
iFIX_稳定状态下最小化CPU的负荷: http://book.ifixonline.com/source/start_opt_minimizing_the_amount_of_cpu_used_in_steady_state.htm
iFIX_测试网络性能: http://book.ifixonline.com/source/start_opt_evaluating_network_performance.htm
iFIX_5.管理多个iFIX用户的最佳方法: http://book.ifixonline.com/source/start_opt_best_practices_for_managing_multiple_ifix_users.htm
iFIX_决定用户类型: http://book.ifixonline.com/source/start_opt_determine_the_user_types.htm
iFIX_确定共享文件夹: http://book.ifixonline.com/source/start_opt_decide_what_folders_you_need_to_share.htm
iFIX_文件夹共享的建议: http://book.ifixonline.com/source/start_opt_recommendations_on_folder_sharing.htm
iFIX_多工程的iFIX目录结构举例: http://book.ifixonline.com/source/start_opt_example_of_the_ifix_directory_structure_for_multiple_projects.htm
iFIX_为每个客户类型创建工程: http://book.ifixonline.com/source/start_opt_create_a_project_for_each_user_type.htm
iFIX_SCU路径配置举例: http://book.ifixonline.com/source/start_opt_example_of_scu_path_configuration.htm
iFIX_使用启动配置文件管理器为项目中的每个用户定义配置文件: http://book.ifixonline.com/source/start_opt_use_the_startup_profile_manager_to_define_profiles_for_each_user_in_a_project.htm
iFIX_使用应用验证器对工程项目进行快照: http://book.ifixonline.com/source/start_opt_use_the_application_validator_to_take_a_snaphsot_of_your_project_folders.htm
电气资料库
70.19 万条内容 · 799 人订阅
ifix3.5教程3
iFIX_在iFIX画面中使用位图: http://book.ifixonline.com/source/start_opt_using_bitmaps_in_ifix_pictures.htm iFIX_刷新iFIX画面显示: http://book.ifixonline.com/source/start_opt_refreshing_ifix_displays.htm iFIX_使用自动缩放: http://book.ifixonline.com/source/start_opt_using_auto_scale.htm
