土木在线论坛 \ 电气工程 \ 电气资料库 \ ifix3.5教程3
ifix3.5教程3
发布于:2007-03-19 11:46:19 来自:电气工程/电气资料库 [复制转发]
iFIX_在iFIX画面中使用位图: http://book.ifixonline.com/source/start_opt_using_bitmaps_in_ifix_pictures.htm
iFIX_刷新iFIX画面显示: http://book.ifixonline.com/source/start_opt_refreshing_ifix_displays.htm
iFIX_使用自动缩放: http://book.ifixonline.com/source/start_opt_using_auto_scale.htm
iFIX_预处理iFIX画面: http://book.ifixonline.com/source/start_opt_resolving_ifix_displays.htm
iFIX_预处理标签: http://book.ifixonline.com/source/start_opt_resolving_tags.htm
iFIX_使用ReplacePicture: http://book.ifixonline.com/source/start_opt_using_replacepicture.htm
iFIX_简化总览画面: http://book.ifixonline.com/source/start_opt_simplify_overview_pictures.htm
iFIX_使用报警一览对象: http://book.ifixonline.com/source/start_opt_using_the_alarm_summary_object.htm
iFIX_减小画面中对象的数量: http://book.ifixonline.com/source/start_opt_minimize_the_number_of_objects_in_each_picture.htm
iFIX_评估使用成组: http://book.ifixonline.com/source/start_opt_evaluating_the_use_of_groups.htm
iFIX_复查打开画面的数量: http://book.ifixonline.com/source/start_opt_reviewing_the_number_of_open_pictures.htm
iFIX_使用定时器对象: http://book.ifixonline.com/source/start_opt_using_timer_objects.htm
iFIX_使用表达式编辑器显示历史标签: http://book.ifixonline.com/source/start_opt_using_the_expression_builder_with_large_historical_tag_lists.htm
电气资料库
70.19 万条内容 · 799 人订阅
ifix3.5教程2
iFIX_升级至iFIX 3.5时保存设置: http://book.ifixonline.com/source/start_gs_preserving_settings_when_upgrading_to_ifix_v3_5.htm iFIX_和iFIX同时启动的数据库Dynamos和客户程序的注意事项: http://book.ifixonline.com/source/start_gs_notes_on_database_dynamos_and_custom_programs_that_run_with_ifix_startup.htm
