土木在线论坛 \ 电气工程 \ 电气资料库 \ ifix3.5教程
ifix3.5教程
发布于:2007-03-19 11:25:19 来自:电气工程/电气资料库 [复制转发]
iFIX_欢迎使用iFIX: http://book.ifixonline.com/source/start_welcomecover.htm
iFIX_文档资料指南: http://book.ifixonline.com/source/start_docmap.htm
iFIX_iFIX3.5新功能: http://book.ifixonline.com/source/start_wncover.htm
iFIX_iFIX 3.5新功能: http://book.ifixonline.com/source/start_wn_whats_new_in_ifix_3_5.htm
iFIX_终端服务器应用程序的改进: http://book.ifixonline.com/source/start_wn_enhancements_for_terminal_server_applications.htm
iFIX_工程项目管理工具: http://book.ifixonline.com/source/start_wn_application_project_management_tools.htm
iFIX_修改SCU: http://book.ifixonline.com/source/start_wn_scu_modifications.htm
iFIX_新的“启动配置文件管理器”应用程序: http://book.ifixonline.com/source/start_wn_new_startup_profile_manager_application.htm
iFIX_新的iFIX启动对话框: http://book.ifixonline.com/source/start_wn_new_ifix_startup_dialog_box.htm
iFIX_新的应用程序验证器: http://book.ifixonline.com/source/start_wn_new_application_validator_utility.htm
iFIX_增强的备份和恢复向导: http://book.ifixonline.com/source/start_wn_enhancements_to_the_backup_and_restore_wizard.htm
iFIX_创建画面向导中支持手持设备屏幕尺寸: http://book.ifixonline.com/source/start_wn_handheld_screen_size_support_in_the_create_picture_wizard.htm
iFIX_OPC增强: http://book.ifixonline.com/source/start_wn_opc_enhancements.htm
iFIX_支持Microsoft Windows Server 2003: http://book.ifixonline.com/source/start_wn_microsoft_windows_net_server_support.htm
iFIX_升级到Microsoft VBA 6.3: http://book.ifixonline.com/source/start_wn_microsoft_vba_v6_3_update.htm
iFIX_支持Stratus ftServer容错技术: http://book.ifixonline.com/source/start_wn_support_of_the_stratus_ftserver_for_fault_tolerance.htm
iFIX_过滤发送至iFIX和FIX32客户端的报警: http://book.ifixonline.com/source/start_wn_ability_to_filter_alarms_sent_to_ifix_and_fix32_clients.htm
iFIX_增强了iFIX VBA的帮助系统: http://book.ifixonline.com/source/start_wn_improved_format_for_the_ifix_vba_help_system.htm
电气资料库
70.19 万条内容 · 799 人订阅
谁愿意提供清晰版GB7251及GB3906等标准
