土木在线论坛 \ 人才招聘 \ 学生专栏 \ 对道路英语精通的进来,英文标书翻译遇到的问题
发布于:2007-03-14 18:23:14 来自:人才招聘/学生专栏 [复制转发]
我正在看一份英文标书,遇到很多问题,我整理了出来(会不断更新),化了我不少时间,肯请回帖的人能把整个句子都翻译完全,并附上序号,方便其他人参考。
  • james7369
    james7369 沙发
    应该不难,有空时再给你翻一下
    2007-04-18 21:23:18
  • xugangseu
    xugangseu 板凳
    1.Fittings and things
    =The contractor shall provide all materials ,fittings and things necessary for the construction and completion of the work.
    2.The contractor with makers or suppliers
    =Two copies of every order placed by the contractor with makers and suppliers approved by the Engineer shall be furnished to the Engineer together with one copy of every drawing referred to in such orders.
    3.Time to time
    =The aggregates to be used shall be laboratory tested to establish their suitability for concrete ,and from time to time check tests shall be made of actual deliveries to the site ,to ensure that uniformity is being maintained.
    4.Hand
    =The contractor shall obtain and hand to the engineer test certificates relating to each delivery of cement.
    5.Grout, mortar and plaster
    =Only clean fresh water shall be used for mixing concrete, grout, mortar and plaster.
    6.Other than
    =For cleaning of formwork ,reinforcement and curing of concrete ,water other than potable water may be used if approved by the engineer.
    Site in rolls
    =No fabric shall be delivered to the site in rolls.
    7.As and when
    =Manufacturer’s test certificates for the steel shall be produced by the contractor as and when required by the Engineer.
    8.All reinforcing steel and fabric shall be free form pitting, loose rust ,mill scale, paint, oil, grease, adhering earth or any other material that may impair the bond between the concrete and the reinforcement or that may cause corrosion of the reinforcement or disintegration of the concrete.
    2007-03-14 18:25:14
学生专栏
23.9 万条内容 · 138 人订阅
施工组织毕业设计
弟正在搞施工组织毕业设计。请教各位。要求砖混结构7层住宅楼啊,大家帮下忙啊,发到我的邮箱中啊,谢谢,我的邮箱是yctdj@163.com
