土木在线论坛 \ 环保工程 \ 水处理 \ 一个论坛截下来的!
一个论坛截下来的!
发布于:2007-03-03 11:27:03 来自:环保工程/水处理 [复制转发]
Extended aeration
« on: Feb 22nd, 2007, 12:23am » Quote Modify
________________________________________
Dear experts,
I would like to consult you about extended aeration tank design, the wastewater characteristics are as follow:
Q 700 m3/d
CODin 1400 ppm
CODeff 20 ppm
TKNin 85 ppm
TKNeff 20 ppm
I tried using the below design criteria:
SRT 20 Days
Y 0.5 Kg/kg
kd 0.05 1/d
MLVSS 4000 ppm
MLSS 5000 ppm
I got a big tank from calculation and hydraulic detention time is very high (>48 hr). Even though, the organic loading rate and F/M are still high.
Would anyone please advise me regading this matter?
Is it possible to use such high detention time? If I use the maximum organic loading rate of 0.4 kgBOD/m3/d (From metcalf) to design, the required volume is 2450 m3 consequently the hydraulic detention time will be as high as 3.5 d that exceeds the hydraualic detention time indicated in Metcalf (18-36 hr).
Thanks anyone who reply in advance.
BGDS,
Nj
Neerajee,
You have quoted influent COD and yet you have done a calculation using BOD/m3/d.
Most extended aeration plants are 18 to 36 hours hydraulic detention time at design load.
Can you confirm whether it is BOD or COD you are basing your design on.
Cheers
Logged
Sorry for typo.
Actually I use BOD.
BOD inf is 1400 mg/L
BOD eff is 20 mg/L
Thanks in advance for any help.
Neerajee
Logged
全部回复(4 )
  • xiaowuwei7007
    xiaowuwei7007 沙发
    呵呵,我的洋文不好呀,看不懂,呜呜呜呜,有人翻译么,谢谢了
    2007-03-05 11:21:05
  • goyc
    goyc 板凳
    仅靠生化很难达到20mg的要求吧
    2007-03-05 11:09:05
水处理
42.33 万条内容 · 1444 人订阅
景观水处理工艺探讨
各位大虾,最近我搞了一个景观水处理工程,水池面积约为100m2,水体积约为60m3,设计流量约为3-4m3/h,原水为市政自来水.在没有经过处理之前,大概一星期左右藻类便明显生长.现我采用以下的工艺流程:原水泵(南方泵)-紫外线杀菌器-多介质过滤器(滤料为活性炭及石英砂,自动头为伊瑞尔568),现在我想问一下,紫外线杀菌器放在前面是否合理,另外,对于处理藻类物质,用何种介质比较好.另外,像这种处理方法,能否保证一年内水质没有明显藻类生长.
