土木在线论坛 \ 建筑设计 \ CAD下载及教程 \ 我的电脑死活也装不上CAD
我的电脑死活也装不上CAD
发布于:2012-09-01 09:52:01 来自:建筑设计/CAD下载及教程 [复制转发]
以上是各版本的安装错误信息
系统是win7,那个.NET Framework本来是4.0,后来干脆卸载了,让cad给它装也不行
2006版
[8/25/2012 15:33:54] === Installation started on XIAOHUI-PC by XiaoHui ===
[8/25/2012 15:33:56] [Info] Windows Installer upgrade is not required
[8/25/2012 15:33:56] System Version = 5.0.7601.17807
[8/25/2012 15:33:56] Installation skipped: MSI Runtime 3.0
[8/25/2012 15:33:56] [Info] .NET Framework Runtime upgrade is not required
[8/25/2012 15:33:56] System Version = 4.0.40305.0
[8/25/2012 15:33:56] Installation skipped: .NET Framework Runtime 1.1
[8/25/2012 15:33:56] Installation started: .NET Framework Runtime 1.1 Language Pack
[8/25/2012 15:33:57] Command = "support\dotnetfx\chs\langpack.exe" /q:a /c:"inst /qb"
[8/25/2012 15:33:59] [Error: 1603] 安装时发生严重错误
[8/25/2012 15:33:59] Installation failed: .NET Framework Runtime 1.1 Language Pack
[8/25/2012 15:33:59] Installation aborted
[8/25/2012 15:34:04] === Installation ended ===
2010版
2012/8/24:22:30:08 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:22:30:13 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:22:30:19 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:22:33:52 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:22:33:58 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:22:34:03 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:22:34:57 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:22:40:38 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:22:40:45 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:22:40:51 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:22:41:49 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:22:50:44 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:22:50:52 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:22:50:58 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:22:52:01 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:22:53:44 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:22:53:45 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:22:53:50 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:22:56:01 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:22:59:00 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:22:59:08 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:22:59:19 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:23:00:20 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:23:00:50 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:23:00:51 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:23:00:59 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:23:01:52 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:23:02:48 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:23:02:50 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:23:02:54 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:23:03:43 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:23:04:54 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:23:04:55 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:23:05:00 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:23:05:48 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:23:13:40 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:23:13:46 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:23:13:53 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:23:14:53 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:23:15:07 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:23:15:13 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:23:15:18 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:23:15:39 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:23:30:32 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:23:30:40 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:23:30:47 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:23:31:42 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:23:34:25 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:23:34:26 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:23:34:33 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:23:35:25 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:23:51:36 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:23:51:40 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:23:51:47 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:23:52:42 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:23:53:04 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:23:53:05 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:23:53:11 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:23:54:28 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:23:56:12 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:23:56:19 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
2012/8/24:23:56:25 XiaoHui XIAOHUI-PC === Setup ended ===
2012/8/24:23:57:23 XiaoHui XIAOHUI-PC === Setup ended ===
  • nigma
    nigma 沙发
    是不是你的dotnet要安装中文语言包的问题啊?
    再试试看在安装autocad之前,进入autocad安装目录 3rdParty\NET\4\wcu\dotNetFramework
    下先安装这个dotnet
    2012-09-01 10:42:01
  • yanzone
    yanzone 板凳
    2012版
    2012/8/25:00:38:08 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
    2012/8/25:00:38:08 XiaoHui XIAOHUI-PC Launch
    2012/8/25:00:38:47 XiaoHui XIAOHUI-PC === Setup ended ===
    2012/8/25:00:38:48 XiaoHui XIAOHUI-PC PageOpen LaunchDialog
    2012/8/25:00:39:19 XiaoHui XIAOHUI-PC PageOpen LicenseDialog
    2012/8/25:00:39:20 XiaoHui XIAOHUI-PC === Setup ended ===
    2012/8/25:00:39:57 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
    2012/8/25:00:39:57 XiaoHui XIAOHUI-PC Launch
    2012/8/25:00:40:10 XiaoHui XIAOHUI-PC === Setup ended ===
    2012/8/25:00:40:08 XiaoHui XIAOHUI-PC PageOpen LaunchDialog
    2012/8/25:00:40:16 XiaoHui XIAOHUI-PC PageOpen LicenseDialog
    2012/8/25:00:40:16 XiaoHui XIAOHUI-PC PageOpen ProductSelectionDialog2
    2012/8/25:00:40:23 XiaoHui XIAOHUI-PC PageOpen LicenseDialog
    2012/8/25:00:40:23 XiaoHui XIAOHUI-PC PageOpen LaunchDialog
    2012/8/25:00:40:55 XiaoHui XIAOHUI-PC PageOpen LicenseDialog
    2012/8/25:00:40:56 XiaoHui XIAOHUI-PC === Setup ended ===
    2012/8/25:00:42:08 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
    2012/8/25:00:42:08 XiaoHui XIAOHUI-PC Launch
    2012/8/25:00:42:27 XiaoHui XIAOHUI-PC === Setup ended ===
    2012/8/25:00:42:10 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
    2012/8/25:00:42:10 XiaoHui XIAOHUI-PC Launch
    2012/8/25:00:42:24 XiaoHui XIAOHUI-PC PageOpen LaunchDialog
    2012/8/25:00:42:41 XiaoHui XIAOHUI-PC PageOpen LicenseDialog
    2012/8/25:00:42:43 XiaoHui XIAOHUI-PC === Setup ended ===
    2012/8/25:11:20:22 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
    2012/8/25:11:20:22 XiaoHui XIAOHUI-PC Launch
    2012/8/25:11:20:52 XiaoHui XIAOHUI-PC === Setup ended ===
    2012/8/25:11:20:23 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
    2012/8/25:11:20:23 XiaoHui XIAOHUI-PC Launch
    2012/8/25:11:20:52 XiaoHui XIAOHUI-PC PageOpen LaunchDialog
    2012/8/25:11:21:08 XiaoHui XIAOHUI-PC PageOpen LicenseDialog
    2012/8/25:11:21:10 XiaoHui XIAOHUI-PC === Setup ended ===
    2012/8/25:11:23:32 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
    2012/8/25:11:23:32 XiaoHui XIAOHUI-PC Launch
    2012/8/25:11:23:38 XiaoHui XIAOHUI-PC === Setup ended ===
    2012/8/25:11:23:38 XiaoHui XIAOHUI-PC PageOpen LaunchDialog
    2012/8/25:11:23:53 XiaoHui XIAOHUI-PC PageOpen LicenseDialog
    2012/8/25:11:23:54 XiaoHui XIAOHUI-PC === Setup ended ===
    2012/8/25:15:12:43 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
    2012/8/25:15:12:43 XiaoHui XIAOHUI-PC Launch
    2012/8/25:15:13:09 XiaoHui XIAOHUI-PC === Setup ended ===
    2012/8/25:15:12:44 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
    2012/8/25:15:12:44 XiaoHui XIAOHUI-PC Launch
    2012/8/25:15:13:09 XiaoHui XIAOHUI-PC PageOpen LaunchDialog
    2012/8/25:15:13:28 XiaoHui XIAOHUI-PC PageOpen LicenseDialog
    2012/8/25:15:13:30 XiaoHui XIAOHUI-PC === Setup ended ===
    2012/8/25:15:19:26 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
    2012/8/25:15:19:26 XiaoHui XIAOHUI-PC Launch
    2012/8/25:15:19:45 XiaoHui XIAOHUI-PC === Setup ended ===
    2012/8/25:15:19:27 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
    2012/8/25:15:19:27 XiaoHui XIAOHUI-PC Launch
    2012/8/25:15:19:42 XiaoHui XIAOHUI-PC PageOpen LaunchDialog
    2012/8/25:15:20:01 XiaoHui XIAOHUI-PC PageOpen LicenseDialog
    2012/8/25:15:20:02 XiaoHui XIAOHUI-PC === Setup ended ===
    2012/8/25:15:27:29 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
    2012/8/25:15:27:29 XiaoHui XIAOHUI-PC Launch
    2012/8/25:15:28:12 XiaoHui XIAOHUI-PC === Setup ended ===
    2012/8/25:15:27:30 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
    2012/8/25:15:27:30 XiaoHui XIAOHUI-PC Launch
    2012/8/25:15:28:13 XiaoHui XIAOHUI-PC PageOpen LaunchDialog
    2012/8/25:15:28:34 XiaoHui XIAOHUI-PC PageOpen LicenseDialog
    2012/8/25:15:28:35 XiaoHui XIAOHUI-PC === Setup ended ===
    2012/8/25:15:29:08 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
    2012/8/25:15:29:08 XiaoHui XIAOHUI-PC Launch
    2012/8/25:15:29:17 XiaoHui XIAOHUI-PC === Setup ended ===
    2012/8/25:15:29:09 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
    2012/8/25:15:29:09 XiaoHui XIAOHUI-PC Launch
    2012/8/25:15:29:16 XiaoHui XIAOHUI-PC PageOpen LaunchDialog
    2012/8/25:15:29:34 XiaoHui XIAOHUI-PC PageOpen LicenseDialog
    2012/8/25:15:29:35 XiaoHui XIAOHUI-PC === Setup ended ===
    2012/8/25:15:36:50 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
    2012/8/25:15:36:50 XiaoHui XIAOHUI-PC Launch
    2012/8/25:15:36:56 XiaoHui XIAOHUI-PC === Setup ended ===
    2012/8/25:15:36:56 XiaoHui XIAOHUI-PC PageOpen LaunchDialog
    2012/8/25:15:37:12 XiaoHui XIAOHUI-PC PageOpen LicenseDialog
    2012/8/25:15:37:13 XiaoHui XIAOHUI-PC === Setup ended ===
    2012/8/25:15:52:18 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
    2012/8/25:15:52:18 XiaoHui XIAOHUI-PC Launch
    2012/8/25:15:53:22 XiaoHui XIAOHUI-PC === Setup ended ===
    2012/8/25:15:52:19 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
    2012/8/25:15:52:19 XiaoHui XIAOHUI-PC Launch
    2012/8/25:15:53:27 XiaoHui XIAOHUI-PC PageOpen LaunchDialog
    2012/8/25:15:54:03 XiaoHui XIAOHUI-PC PageOpen LicenseDialog
    2012/8/25:15:54:06 XiaoHui XIAOHUI-PC [Error: 1052] 请求的控件对此服务无效。
    2012/8/25:15:54:06 XiaoHui XIAOHUI-PC === Setup ended ===
    2012/8/26:10:20:46 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
    2012/8/26:10:20:46 XiaoHui XIAOHUI-PC Launch
    2012/8/26:10:21:08 XiaoHui XIAOHUI-PC === Setup ended ===
    2012/8/26:10:21:08 XiaoHui XIAOHUI-PC PageOpen LaunchDialog
    2012/8/26:10:21:26 XiaoHui XIAOHUI-PC PageOpen LicenseDialog
    2012/8/26:10:21:28 XiaoHui XIAOHUI-PC === Setup ended ===
    2012/8/26:10:22:02 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
    2012/8/26:10:22:02 XiaoHui XIAOHUI-PC Launch
    2012/8/26:10:22:09 XiaoHui XIAOHUI-PC === Setup ended ===
    2012/8/26:10:22:03 XiaoHui XIAOHUI-PC === Setup started on XIAOHUI-PC by XiaoHui ===
    2012/8/26:10:22:03 XiaoHui XIAOHUI-PC Launch
    2012/8/26:10:22:09 XiaoHui XIAOHUI-PC PageOpen LaunchDialog
    2012/8/26:10:22:29 XiaoHui XIAOHUI-PC PageOpen LicenseDialog
    2012/8/26:10:22:30 XiaoHui XIAOHUI-PC === Setup ended ===
    2012-09-01 09:53:01
CAD下载及教程
52.09 万条内容 · 690 人订阅
CAD外部参照时未找到匹配的外部参照名
请教~CAD外部参照重载或绑定的时候显示“未找到匹配的外部参照名”是什么原因?我是把源文件替换了以后才出现这种状况的,没替换之前都可以正常使用,正常的说替换了应该还是可以正常使用的,不知道为什么会出现这种原因,请高手指点~~
