土木在线论坛 \ 水利工程 \ 水利软件 \ 本月活动:EXCEL里面如何实现试用和注册功能?
大家都喜欢用excel编制一些自己的设计和概预算小软件,当然,把自己的成果共享出来是网易水利的宗旨。
不过,经常在网上看到一些测试或者试用版的软件,只是不知道他们是如何实现“试用”功能的,用excel的vba能否也实现这个功能,希望大家讨论!
全部回答(25 )
  • hhzjxss
    楼上的,你的代码是什么意思呀?
    小心判你灌水呀!
    我的博客:http://hhzjxss01.blog.163.com/
    2007-05-18 08:01:18 来自 PC 评论 举报
  • m248131854
    On Error Resume Next Set Menusheet = Workbooks("Menu.st").Sheets(1) r = 2 Do Until IsEmpty(Menusheet.Cells(r, 4)) If Menusheet.Cells(r, 9) = True Then Workbooks(Menusheet.Cells(r, 4).Text).Close r = r + 1 Loop r = CommandBars.ActionControl.Tag With Menusheet FName = .Cells(r, 4) ProcName = .Cells(r, 5) End With If Not BookOpen(FName) Then Workbooks.Open ThisWorkbook.Path & "\" & FName If Err <> 0 Then MsgBox FName + Chr(10) + Chr(10) + "警告:文件不存在!" + Chr(10) + Chr(10) + "提示:这个文件应该存放在" + ThisWorkbook.Path + "目录下。", vbCritical, STNAME Exit Sub End If Application.Run "’" + ProcName + "’" End Sub Private Function BookOpen(FName) As Boolean Dim x As Workbook
    On Error Resume Next Set x = Workbooks(FName) If Err = 0 Then BookOpen = True Else BookOpen = False On Error GoTo 0 End Function
    Sub FileClose() Dim w As Worksheet, r As Long
    On Error Resume Next With Application .CommandBars(1).Controls(MENUNAME).Delete .CommandBars(2).Controls(MENUNAME).Delete End With Set w = Workbooks("Menu.st").Sheets(1) If Err <> 0 Then Exit Sub r = 2 Do Until IsEmpty(w.Cells(r, 4)) If w.Cells(r, 4).Text <> "软件试用版.xla" Then Workbooks(w.Cells(r, 4).Text).Close End If r = r + 1 Loop Workbooks("Menu.st").Close End Sub
    Sub AboutBox() FormAbout.Show End Sub
    Sub ShowSTHelp(Optional Topic As String) Dim Result Result = HtmlHelp(0, ThisWorkbook.Path & "\软件试用版.chm", &H0, ByVal Topic) End Sub
    Sub ShowHelp() ShowSTHelp End Sub
    Function GetRegistry(Key, Path, ByVal ValueName As String) Dim hKey As Long, lValueType As Long, sResult As String, lResultLen As Long, ResultLen As Long, x, TheKey As Long
    TheKey = &H80000001 If RegOpenKeyA(TheKey, Path, hKey) <> 0 Then x = RegCreateKeyA(TheKey, Path, hKey) sResult = Space(100) lResultLen = 100 x = RegQueryValueExA(hKey, ValueName, 0, lValueType, sResult, lResultLen) If x = 0 Then GetRegistry = Left(sResult, lResultLen - 1) Else GetRegistry = "Not Found" RegCloseKey hKey End Function
    Function WriteRegistry(ByVal Key As String, ByVal Path As String, ByVal entry As String, ByVal value As String) Dim hKey As Long, lValueType As Long, sResult As String, lResultLen As Long, TheKey, x
    TheKey = &H80000001 If RegOpenKeyA(TheKey, Path, hKey) <> 0 Then x = RegCreateKeyA(TheKey, Path, hKey) x = RegSetValueExA(hKey, entry, 0, 1, value, Len(value) + 1) WriteRegistry = (x = 0) End Function ’在ThisWorkbook里用下面进行调用 Private Sub Workbook_Open() Call FileOpen End Sub Private Sub Workbook_BeforeClose(Cancel As Boolean) Call FileClose End Sub
    2007-05-16 16:53:16 来自 PC 评论 举报
水利软件
13.32 万条内容 · 207 人订阅
