土木在线论坛 \ 人才招聘 \ 学生专栏 \ Special Steel英文句子(工作中收集的)
发布于:2007-02-10 17:15:10 来自:人才招聘/学生专栏 [复制转发]
General
轴承合金
Bearing Alloy 锡基、铅基及锌基轴承合金比较表
Comparison of Tin base, Lead base and Zinc base alloy for Bearing purpose
易溶合金 Fusible Alloy
焊接合金 Soldering and Brazing Alloy
软焊 Soldering Alloy
软焊合金Soldering Alloy
硬焊 Brazing Alloy
细线材、枝材、棒材
  • andyhewitt
    andyhewitt 沙发
    Classes, symbols, twisting characteristic and applied Wire Diameters
    直径,公差及拉力强度
    Diameter, Tolerance and Tensile Strength
    裂纹之容许深度及脱碳层
    Permissible depth of flaw and decarburized layer
    常用的弹簧不锈钢线-编号,特性,表面处理及化学成份
    StainlessSpring Wire – National Standard number, Charateristic, Su***ce finish & Chemical composition
    弹簧不锈钢线,线径及拉力列表
    Stainless Spring Steel, Wire diameter and Tensile strength of Spring Wire
    处理及表面状况
    Tensile Strength of various kinds of Stainless Steel Wire under Different Finish
    圆径及偏圆度之公差
    Tolerance of Wire Diameters & Ovality
    铬镍不锈钢及抗热钢弹簧线材 – 美国材验学会 ASTM A313 – 1987
    Chromium – Nickel Stainless and Heat-resisting Steel Spring Wire – ASTM A313 – 1987
    化学成份 Chemical Composition
    机械性能 Mechanical Properties
    305, 316, 321及347之拉力表
    Tensile Strength Requirements for Types 305, 316, 321 and 347
    2007-02-10 17:18:10
  • andyhewitt
    andyhewitt 板凳
    Carbon Steel Wire Rods for Cold Heading & Cold Forging 级别,代号及化学成份
    Classification, Symbol of Grade and Chemical Composition
    直径公差,偏圆度及脱碳层的平均深度
    Diameter Tolerance, Ovality and Average Decarburized Layer Depth
    冷拉钢枝材
    Drawn Carbon Steel Shafting Bar
    冷拉钢板重量表
    Cold Drawn Steel Bar Weight Table
    高碳钢线枝
    High Carbon Steel Wire Rod
    冷拉高碳钢线
    Hard Drawn High Carbon Steel Wire
    化学成份分析表
    Chemical Analysis of Wire Rod
    线径、公差及机械性能
    Mechanical Properties琴线
    Piano Wires级别,代号,扭曲特性及可用之线材直径
    2007-02-10 17:17:10
学生专栏
23.9 万条内容 · 138 人订阅
英文K人必备109句
挺有意思,记住了起码不会让人骂得不明不白嘛 而且~还可以提高英语呢~!何乐而不为呢~!呵呵@
