土木在线论坛 \ 建筑结构 \ 结构设计软件 \ SAP2000 V11
SAP2000 V11
发布于:2007-02-06 22:14:06 来自:建筑结构/结构设计软件 [复制转发]
今天在CSI公司的官方网站上看到了SAP2000的V11版本已经出炉了。实在是太快了,这么快就更新了。
现在把SAP2000的V11版本增强说明贴出来。
里面提到了V11版本在设计,分析等各个方面做了改进。
SAP2000 – V11 – Enhancements List
Computers and Structures, Inc.’s significantly enhanced SAP2000 V11 is now shipping. Advancements have been made to almost every aspect of the program, including new graphics and new solvers. This fully integrated application for the modeling, analysis, and design of structures continues to be available in three levels: Basic, Plus and Advanced. The new and innovative features of Version 11 are listed below. Please contact sales@csiberkeley.com for more information.
Graphical User Interface (GUI)
· OpenGL graphics added to main model window for fast drawing and display
· Drawing significantly improved with several intelligent snaps and constraints
· On-the-fly working plane added for modeling at arbitrary orientations
· Numerous new selection methods added, including parallel to object, polygon fence and
poly-line intersection, and by supports and constraints
· "Fly" through models using user-defined paths
· Selection by any combination of input or output values using database tables
· Right-button information forms now allow easy editing of all items
· Forms requiring previously defined items now allow adding/editing of those items
· Materials redone to improve usability
· Frame Sections redone to improve usability
· User notes can be added to all properties
· Fireproofing assignment added to frame objects
· Automated undeformed geometry modifications using displaced shape
· Database table display improved, including filters and selection
· Help topics added to some forms
Membership to CSIDN (CSI-Developer Network) now available
· Application Programing Interface (API) for custom programming or interfacing
to other programs (available for Advanced, Plus, and Basic)
New Object Types
· Area objects can now be general polygons with more than 4 nodes
· Area object meshing improved to account for general polygons
· Catenary cable object/element added
New Automated Lateral Loads
· Automatic generation of lateral Notional loads for design
· IBC 2006 Seismic load and response spectrum function added
· IBC 2006 Wind load added
Analytical Model
· Nonlinear link properties can now be assigned as distributed springs on Line,
Area, and Solid Objects
· Null property assignments to Line and Area and Solid objects are now allowed
· Analysis model (element level) displays added, including loads and assignments
· Analysis model information available for any element with a right-button click
Bridge Modeler Add-On (works with Advanced and Plus)
· Bridge Wizard enhanced
· Easier variable-section assignment for bridges
· Advanced concrete box girder bridge section added
· I and U precast bridge girder sections added
· Specify prestress tendon jacking using force or displacement
· AASHTO and NCHRP Project 20-07 response spectrum functions added
· Nonlinear temperature distribution allowed for deck
· Caltrans Section Designer sections added to database tables
Analysis
· New deformation loads added to Frame and Cable elements
· Automatic iteration for target forces in Frame and Cable elements
· 64-bit support added for analysis engine
Design
· ACI 2005/IBC 2006 concrete design added
· AISC 2005/IBC 2006 steel design added
· Canadian 2004 concrete design added
Documentation
· SAP2000 V11 User Manual
- Getting Started
- Basic Analysis Reference
- Introductory Tutorial
· Program help updated
· Design documentation updated (PDF file)
· Verification updated (PDF files or Printed)
· Automated lateral loads added (PDF files or Printed)
· "Watch & Learn™ Movies" new and updated
· A – Z examples updated
· Application Programming Interface (API) (PDF files)
全部回复(9 )
  • httpuser2
    httpuser2 沙发
    不错,等中文版。
    2010-08-02 15:31:02
  • liu1735
    liu1735 板凳
    很好地软件 没有必要升级的那么快的
    2007-03-23 22:01:23
结构设计软件
41.51 万条内容 · 299 人订阅
建筑业是否是万岁的事业!!!
建筑业是否是万岁的事业!!!
