土木在线论坛 \ 站务休闲 \ 站长办公室 \ 谁来帮我翻译毕业论文
谁来帮我翻译毕业论文
发布于:2007-01-25 19:44:25 来自:站务休闲/站长办公室 [复制转发]
This paper describes simulation-based results of an investigation of a commercial cooling plant with an ice storage system. Various ice storage systems, chiller compressors, and building types were analyzed under four different control strategies. Optimal control as the strategy that minimizes the total operating cost (demand and energy charges) served as a benchmark to assess the relative performance of three conventional controls (chiller-priority, constant-proportion, and storage-priority control) and to determine aspects in need of improvement in order to apply these conventional controls better and to enhance the cost saving potential of ice storage systems.
Independent of the non-cooling electrical load profile, it was found that good efficiency of the cooling plant in the icemaking mode and rate structures with strong load-shifting incentives are prerequisites for making cool storage successful. Chillers with poor performance at subfreezing evaporator temperatures require significant on- to off-peak differentials in the energy and demand rates to yield substantial savings. The relative performance benefit of optimal control over conventional controls increases when rate-based load-shifting incentives are weak. With cooling-related electrical loads being large compared to non-cooling loads, all conventional controls improve their performance when slowly recharging during off-peak periods to contain off-peak demand. On-peak demand reduction of storage-priority is near-optimal for many cases. Guidelines are presented to improve the load-shifting performance of chiller-priority and constant-proportion control. # 2002 Elsevier Science B.V. All rights reserved.
Keywords: Commercial buildings; Equipment; Thermal energy storage systems; Optimization; Guidelines
  • zhengshg1979
    zhengshg1979 沙发
    大哥,这个你没有学习专业英语嘛,这也不是考试,可以查词典啊,还用到这里来求人吗
    2007-01-29 16:39:29
站长办公室
61.75 万条内容 · 51 人订阅
怎样快速查看到自己的留言内容?
我的问题是:自己经常回答别的网友的问题或参加讨论,有的时候会忘记自己的留言内容.这时候,想看自己的留言内容时,往往要把帖子浏览完才能看到自己的留言部分,很麻烦,哪位高人有什么办法,能让自己在我参与过的主题中快速看到自己的留言内容?
