土木在线论坛 \ 注册考试 \ 注册土木工程师 \ 冲压模具常用词汇英文对照
冲压模具常用词汇英文对照
发布于:2012-08-09 16:36:09 来自:注册考试/注册土木工程师 [复制转发]
我们在模具行业工作久了,可能也常要和一些模具单词打交道,比如说你想用CAD作个二次开发,就会要用到图层,而对应到模具中,就要用到这些英文模具词汇,例如你想新建一个下模板层,这时你就会想到用DIE这个名字来命名这个图层,我们常用的presscad就是这样命名的!
下面为模具零件及相关:
stamping, press冲压 punch press, dieing out press冲床 uncoiler & strainghtener整平机 feeder送料机 rack, shelf, stack料架 cylinder油缸 robot机械手 taker取料机 conveyer belt输送带 transmission rack输送架 top stop上死点 bottom stop下死点 one stroke一行程 inch寸动 to continue, cont.连动 to grip(material)吸料 location lump, locating piece, block stop 定位块 reset复位 smoothly顺利 dent压痕 scratch刮伤 deformation变形 filings铁削 to draw holes抽孔 inquiry, search for查寻 to stock, storage, in stock库存 receive领取 approval examine and verify审核 processing, to process加工 delivery, to deliver 交货 to return delivenry to .to send delinery back to retrn of goods退货 registration登记 registration card登记卡 to control管制 to put forward and hand in提报 safe stock安全库存 acceptance = receive验收 to notice通知 application form for purchase请购单 consume, consumption消耗 to fill in填写 abrasion磨损 reverse angle = chamfer倒角 character die字模 to collect, to gather收集 failure, trouble故障 statistics统计 demand and supply需求 career card履历卡 to take apart a die卸下模具 to load a die装上模具 to tight a bolt拧紧螺栓 to looser a bolt拧松螺栓 to move away a die plate移走模板 easily damaged parts易损件 standard parts标准件 breaking.(be)broken,(be)cracked 断裂 to lubricate润滑 common vocabulary for die engineering
以下为冲压模具
die 模具 figure file, chart file图档 cutting die, blanking die冲裁模 progressive die, follow (-on)die 连续模 compound die复合模 punched hole冲孔 panel board镶块 to cutedges=side cut=side scrap切边 to bending折弯 to pull, to stretch拉伸 Line streching, line pulling线拉伸 engraving, to engrave刻印 upsiding down edges翻边 to stake铆合 designing, to design设计 design modification设计变化 die block模块 folded block折弯块 sliding block滑块 location pin定位销 lifting pin顶料销 die plate, front board模板 padding block垫块 stepping bar垫条 upper die base上模座 lower die base下模座 upper supporting blank上承板 upper padding plate blank上垫板 spare dies模具备品 spring 弹簧 bolt螺栓
转载请注明文章转载自:网络资源 [ http://www.makehao.com]
本文链接地址:冲压模具常用词汇英文对照
注册土木工程师
6.76 万条内容 · 269 人订阅
2012一级建造师复习资料(含五册)
2012一级建造师复习资料(含五册)主要是要点归纳,希望对大家有帮助
