土木在线论坛 \ 建筑结构 \ ANSYS \ 大家都来看,求助,这是出了什么问题
大家都来看,求助,这是出了什么问题
发布于:2012-07-20 18:04:20 来自:建筑结构/ANSYS [复制转发]
错误文件中出了下列警告和错误,用的是SHELL181单元,进行非线性分析
*** WARNING *** CP = 6.484 TIME= 17:59:53
Hyper-elastic material may become unstable, material number 1 at
temperature 0.
*** WARNING *** CP = 12.750 TIME= 18:00:06
There are 11212 small equation solver pivot terms.
*** WARNING *** CP = 12.828 TIME= 18:00:06
Plane stress hyperelasticity did not converge for out of plane stretch.
*** WARNING *** CP = 12.844 TIME= 18:00:06
*** WARNING *** SUPPRESSED MESSAGE CP = 12.844 TIME= 18:00:06
*** WARNING *** SUPPRESSED MESSAGE CP = 16.781 TIME= 18:00:12
There are 10905 small equation solver pivot terms.
*** WARNING *** SUPPRESSED MESSAGE CP = 16.828 TIME= 18:00:12
*** WARNING *** SUPPRESSED MESSAGE CP = 20.641 TIME= 18:00:17
There are 10422 small equation solver pivot terms.
*** WARNING *** SUPPRESSED MESSAGE CP = 20.688 TIME= 18:00:17
*** WARNING *** SUPPRESSED MESSAGE CP = 24.500 TIME= 18:00:21
There are 9584 small equation solver pivot terms.
*** WARNING *** SUPPRESSED MESSAGE CP = 24.562 TIME= 18:00:21
*** WARNING *** SUPPRESSED MESSAGE CP = 28.344 TIME= 18:00:26
There are 8595 small equation solver pivot terms.
*** WARNING *** SUPPRESSED MESSAGE CP = 28.422 TIME= 18:00:26
*** WARNING *** SUPPRESSED MESSAGE CP = 32.203 TIME= 18:00:31
There are 8242 small equation solver pivot terms.
*** WARNING *** SUPPRESSED MESSAGE CP = 32.281 TIME= 18:00:31
The unconverged solution (identified as time 1 substep 999999) is
output for analysis debug purposes. Results should not be used for
any other purpose.
哪位高手帮忙指点迷津,十分感谢。
ANSYS
4.39 万条内容 · 152 人订阅
ansys 14 运行故障
ansys 14.0按照步骤安装完后,运行,RUN后出现如下界面,不知如何解决,求助啊 ······
