土木在线论坛 \ 建筑设计 \ CAD下载及教程 \ 【悬赏活动2】求封闭区域的面积、形心和周长
发布于:2007-01-07 09:54:07 来自:建筑设计/CAD下载及教程 [复制转发]
程序功能:求封闭区域的面积、形心和周长,封闭区域系指由封闭LWPolyLine或Line实体围成的闭合区域(可不考虑内部孤岛)
程序交互要求:给出两种命令行交互方式,选择内部点方式和选择外围连续闭合LWPolyLine的方式,程序结果在命令行输出。
扩展(不属于本次活动内容):给出一组LWPolyLine或Line实体,求由这些实体围成的封闭区域
本问题最佳答案奖励积分180。
全部回复(15 )
  • whereiswill
    whereiswill 沙发
    ;;功能:增强表达式的计算
    ;;文件:calu.lsp
    ;;命令:ca或'ca透明调用
    ;;使用:增强支持符号 %=百分比 T=取文字数值 S=取对象面积 L=取对象长度 C=使用计算器
    ;; 整数运算不受32767的限制
    ;; 对表达式预运算避免图面取点后再提示错误
    ;;作者:YAD
    (defun c:ca(/ str_replace str_dis get_val ~e ~str ~oldstr ~test ~tsl ~n ~tn ~sn ~ln ~strnew ~txt ~pt ~ss ~ent)
    (defun str_replace(st sty val / str tmp n txt end)
    (cond
    ((= sty "num")
    (setq str "" tmp "" n 0)
    (repeat (strlen st)
    (setq txt (substr st (setq n (1+ n)) 1))
    (if (wcmatch txt "#,`.")
    (setq tmp (strcat tmp txt))
    (progn
    (if (/= tmp "")
    (setq tmp (if (wcmatch tmp "*`.*") tmp (strcat tmp ".")) str (strcat str tmp) tmp "")
    (setq str (strcat str (if (= txt "%") "/100.0" txt)))
    (if (/= tmp "")
    (setq tmp (if (wcmatch tmp "*`.*") tmp (strcat tmp ".")) str (strcat str tmp))
    ((= sty "test")
    (foreach itm '("END" "INS" "INT" "MID" "CEN" "NEA" "NOD" "QUA" "PER" "TAN" "CUR" "ILLE" "MEE" "NEE" "VEE")
    (while (wcmatch st (strcat "*" itm "*")) (setq st (vl-string-subst val itm st)))
    (foreach itm '("RAD" "DEE")
    (while (wcmatch st (strcat "*" itm "*")) (setq st (vl-string-subst "1" itm st)))
    (setq str st)
    ((= sty "T,S,L")
    (setq str "" n 0)
    (repeat (strlen st)
    (if (and (wcmatch txt sty) (or (= n 1) (member (substr st (1- n) 1) '("+" "-" "*" "/" "(")))
    (member (substr st (1+ n) 1) '("+" "-" "*" "/" "^" ")" ""))
    (setq str (strcat str val) ~tsl T)
    (setq str (strcat str txt))
    (T
    (setq str "" n 0)
    (repeat (strlen st)
    (if (and (not end) (= txt sty) (or (= n 1) (member (substr st (1- n) 1) '("+" "-" "*" "/" "(")))
    (setq str (strcat str val) end T)
    str
    (defun str_dis(val)
    (if (and (= (type val) 'real) (> val 999999.0)) (rtos val) (vl-princ-to-string val))
    (defun get_val(txt / str2num ss n m ent val)
    (defun str2num(str / e n st st1 st2)
    (setq e T n 0)
    (while (and e (/= "" (setq st (substr str (setq n (1+ n)) 1))))
    (if (wcmatch st "#")
    (setq st1 (if (> n 1) (substr str (1- n) 1) "a")
    st2 (if (> n 2) (substr str (- n 2) 1) "b")
    str (substr str n)
    e nil
    (if (wcmatch str "*#*")
    (progn
    (setq e T n 0)
    (if (not (wcmatch st "#,`."))
    (setq str (substr str 1 (1- n)) e nil)
    (if (= st1 "-")
    (setq str (strcat st1 str))
    (if (= st1 ".")
    (if (= st2 "-")
    (setq str (strcat st2 st1 str))
    (if (= st "%")
    (/ (atof str) 100)
    (atof str)
    (prompt (strcat "\nYAD>> 计算表达式: " ~oldstr "\n>> 给第"
    (itoa (cond ((= txt "T") (setq ~tn (1+ ~tn))) ((= txt "S") (setq ~sn (1+ ~sn))) ((= txt "L") (setq ~ln (1+ ~ln)))))
    "个" txt "符号选择对象!"
    (if (setq ss (ssget (list (cons 0 (cond ((= txt "T") "text")
    ((= txt "S") "arc,circle,ellipse,lwpolyline,spline")
    ((= txt "L") "arc,circle,ellipse,line,lwpolyline,spline")
    (progn
    (setq n -1 m 0)
    (repeat (sslength ss)
    (setq ent (ssname ss (setq n (1+ n))))
    (cond
    ((= txt "T")
    (setq val (str2num (cdr (assoc 1 (entget ent)))))
    ((= txt "S")
    (setq val (vla-get-Area (vlax-ename->vla-object ent)))
    ((= txt "L")
    (setq ent (vlax-ename->vla-object ent))
    (setq val (vlax-curve-getDistAtParam ent (vlax-curve-getEndParam ent)))
    (setq m (+ m val))
    (setq m 0)
    (prompt (strcat "\n>> 第" (itoa (cond ((= txt "T") ~tn) ((= txt "S") ~sn) ((= txt "L") ~ln))) "个" txt "=" (str_dis m)))
    (rtos m 2 6)
    (if (not cal) (arxload "geomcal.arx"))
    (setvar "cmdecho" 0)
    (prompt "\n**遵照标准数学表达式和优先级计算规则计算\n**增强支持符号:%=百分比 T=取文字数值 S=取对象面积 L=取对象长度 C=使用计算器")
    (setq ~e T ~str nil)
    (while (and ~e (/= ~str "C") (/= (setq ~str (strcase (setq ~oldstr (getstring "\nYAD>> 计算表达式: ")))) ""))
    (setq ~str (str_replace ~str "num" ".") ~test (str_replace ~str "T,S,L" "1"))
    (cond
    ((= ~str "C") (startapp "calc.exe"))
    ((not (cal (str_replace ~test "test" "[1,1,1]"))))
    (T
    (if ~tsl
    (progn
    (setq ~n 0 ~tn 0 ~sn 0 ~ln 0 ~strnew ~str)
    (repeat (strlen ~str)
    (setq ~txt (substr ~str (setq ~n (1+ ~n)) 1))
    (if (and (member ~txt '("T" "S" "L")) (or (= ~n 1) (member (substr ~str (1- ~n) 1) '("+" "-" "*" "/" "(")))
    (member (substr ~str (1+ ~n) 1) '("+" "-" "*" "/" "^" ")" ""))
    (setq ~strnew (str_replace ~strnew ~txt (get_val ~txt)))
    (setq ~str ~strnew)
    (if (setq ~str (cal ~str))
    (progn
    (if (/= (getvar "cmdnames") "") (setq ~e nil))
    (prompt (strcat "\nYAD>> 计算表达式: " ~oldstr "\n>> 结果: " (str_dis ~str)))
    (if ~tsl
    (progn
    (setq ~tsl nil ~n -1)
    (if (setq ~pt (getpoint "\n点取标注位置: <文字替换> "))
    (entmake (list (cons 0 "TEXT") (cons 100 "AcDbEntity") (cons 100 "AcDbText") (cons 10 ~pt)
    (cons 40 (getvar "textsize")) (cons 1 (rtos ~str)) (cons 100 "AcDbText")
    (if (setq ~ss (ssget '((0 . "text"))))
    (repeat (sslength ~ss)
    (setq ~ent (entget (ssname ~ss (setq ~n (1+ ~n)))))
    (entmod (subst (cons 1 (rtos ~str)) (assoc 1 ~ent) ~ent))
    (if (= (getvar "cmdnames") "")
    (princ)
    (progn (princ "\n") ~str)
    网上的 但是不能标注出来 只能标注“0 ” 请问大师可以修改一下吗
    2008-11-11 15:26:11
  • whereiswill
    whereiswill 板凳
    十分感谢
    请教是否可以把 面积 周长 直接自己自动标注在图纸之中,而同时显示在命令行,请问应该把上面的 lsp 文件如何修改
    不胜感激!!!!!!!
    要是可以劳烦您发一个到 whereiswill@163.com 就是阿弥陀佛了:)
    2008-11-11 15:20:11
CAD下载及教程
52.09 万条内容 · 690 人订阅
关于镜像的问题
有没有将楼板钢筋一次性镜像,主要是板顶筋和底筋的方向问题
