发布于:2012-06-20 23:12:20
来自:建筑结构/武汉老庄结构院
[复制转发]
看到有人贴的测量封闭区域面积LSP不咋滴,所以贴2个好点的lsp程序出来。。。是经的起时间的考验的(呵呵)。
复制到记事本中,另存为 XX.lsp 然后在CAD中 工具-加载应用程序 中加载。文中 (defunC:TT(/XYSIZESSAREASTRTMP)
C:后的,TT 为使用时要输入的命令。
(setvar "CMDECHO" 0)
(vl-load-com)
;;;功能:测量封闭区域的面积(可分别设置XY比例) *
;;;日期:zml84 于 2009-06-07 *
(defun C:TT (/ X Y SIZE SS AREA STR TMP)
;; 0 初始化
(or *TEST_TMP*
(setq *TEST_TMP* '(1000 100 2.5))
(setq X (nth 0 *TEST_TMP*)
Y (nth 1 *TEST_TMP*)
SIZE (nth 2 *TEST_TMP*)
;; 1
(while
(progn
(princ
(strcat
"\n当前设置:X比例="
(rtos X)
",X比例="
(rtos Y)
",字高="
(rtos SIZE)
(initget "X Y Size")
(princ
"\n点取要测量面积的封闭对象,或 [X比例(X)/Y比例(Y)/字高(S)]: "
(setq SS (entsel ""))
(cond ((= SS "X")
(if (and (setq TMP (getreal "\n设置X向比例: "))
(> TMP 0)
(setq X TMP)
((= SS "Y")
(if (and (setq TMP (getreal "\n设置Y向比例: "))
(> TMP 0)
(setq Y TMP)
((= SS "Size")
(if (and (setq TMP (getreal "\n设置字体高度: "))
(> TMP 0)
(setq SIZE TMP)
((and (setq
AREA (vla-get-area
(vlax-ename->vla-object (car SS))
(setq AREA (/ AREA 1.0 X Y)
STR (rtos AREA 2 3)
(princ (strcat "\n**面积 = " STR))
(setq PT (getpoint "\n文字的位置: "))
(command "_.TEXT" "non" PT SIZE 0 STR)
;; 2
(setq *TEST_TMP* (list X Y SIZE))
(princ)
;;;功能:点取内部一点,测量封闭区域的面积(可分别设置XY比例) *
(defun C:TT2 (/ X Y SIZE PT EN AREA STR TMP)
;; 0 初始化
(or *TEST_TMP*
;; 1
(while
(progn
(princ
(strcat
"\n当前设置:X比例="
(rtos X)
",X比例="
(rtos Y)
",字高="
(rtos SIZE)
(princ
"\n点取要测量的位置,或 [X比例(X)/Y比例(Y)/字高(S)]: "
(setq PT (getpoint ""))
(cond ((= PT "X")
(> TMP 0)
(setq X TMP)
((= PT "Y")
(> TMP 0)
(setq Y TMP)
((= PT "Size")
(> TMP 0)
(setq SIZE TMP)
((and
(setq EN (bpoly PT))
(setq
AREA (vla-get-area
(vlax-ename->vla-object EN)
;;(progn (command "REGEN") (redraw EN 3) t)
(entdel EN)
STR (rtos AREA 2 3)
;; 2
(princ)
只看楼主 我来说两句抢地板回复 举报
