土木在线论坛 \ 给排水工程 \ 给排水资料库 \ 建筑防水方面词汇
建筑防水方面词汇
发布于:2006-12-13 20:55:13 来自:给排水工程/给排水资料库 [复制转发]
石油沥青纸胎油毡、油纸 Paper base petroleum asphalt felt asphalt paper
沥青防水卷材试验方法 总则 Test methods for asphalt waterproof roll roofing—The general rules
沥青防水卷材试验方法 浸涂材料含量 Test methods for asphalt waterproof roll roofing—Saturated and coated bitumen amount of asphalt
沥青防水卷材试验方法 不透水性 Test methods for asphalt waterproof roll roofing— Water impermeability of asphalt
沥青防水卷材试验方法 吸水性 Test methods for asphalt waterproof roll roofing — Water absorption of asphalt
沥青防水卷材试验方法 耐热度 Test methods for asphalt waterproof roll roofing—Heat resistance of asphalt
沥青防水卷材试验方法 拉力 Test methods for asphalt waterproof roll roofing—Tensile strength of asphalt
沥青防水卷材试验方法 柔度 Test methods for asphalt waterproof roll roofing—Flexibility of asphalt
环形钢筋混凝土电杆 Circular reinforced concrete pole
抗硫酸盐硅酸盐水泥 Sulfate resistance portland cement
水泥抗硫酸盐侵蚀试验方法 Sulphate resistance test for cement
水泥压蒸安定性试验方法 Autoclave method for soundness of portland cement
矿渣硅酸盐水泥、火山灰质硅酸盐水泥及粉煤灰硅酸盐水泥 Portland blastfurnace-slag cement, portland pozzolana cement and portland fly-ash cement
水泥细度检验方法 (μm筛筛析法) Test method for fineness of cement--The μm sieve
水泥标准稠度用水量、凝结时间、安定性检验方法 Standard test method for water requirement of normal consistency setting time and soundness of the portland cement
纤维增强塑料性能试验方法总则 The generals of test methods for properties of fiber-reinforced plastics
玻璃纤维增强塑料拉伸性能试验方法 Test method for tensile properties of glass fiber-reinforced plastics
玻璃纤维增强塑料压缩性能试验方法 Test method for compressive properties of glass fiber-reinforced plastics
玻璃纤维增强塑料弯曲性能试验方法 Test method for flexural properties of glass fiber-reinforced plastics
玻璃纤维增强塑料层间剪切强度试验方法 Test method for interlaminar shear strength of glass fiber-reinforced plastics
玻璃纤维增强塑料冲压式剪切强度试验方法 Test method for the punch-type of strength of glass fiber-reinforced plastics
玻璃纤维增强塑料简支梁式冲击韧性试验方法 Test method for the charpy impact resistance of glass fiber-reinforced plastics
非金属夹层结构平拉强度试验方法 Test method for flatwise tension strength of nonmetal sandwich constructions
非金属夹层结构或芯子平压性能试验方法 Test method for flatwise compression properties of nonmetal sandwich constructions or cores
夹层结构侧压性能试验方法 Test method for edgewise compressive properties of sandwich constructions
夹层结构或芯子剪切性能试验方法 Test method for shear properties of sandwich constructions or cores
夹层结构弯曲性能试验方法 Test method for flexural properties of sandwich constructions
夹层结构滚筒剥离试验方法 Test method for climbing drum peel of sandwich constructions
纤维缠绕增强塑料环形试样拉伸试验方法 Test method for tensile strength of ring of filament- winding reinforced plastics
纤维缠绕增强塑料环形试样剪切试验方法 Test method for interlaminar shear strength of ring of filament-winding reinforced plastics
纤维增强塑料吸水性试验方法 Test methods for water absorption of fiber reinforced plastics
纤维增强塑料密度和相对密度试验方法 Test methods for density and relative density of fiber reinforced plastics
非金属夹层结构或芯子密度试验方法 Test method for density of nonmetal sandwich constructions or cores
全部回复(3 )
  • lyaizyq512
    lyaizyq512 沙发
    不简单 呵呵
    2013-08-27 11:42:27
  • lhdrh
    lhdrh 板凳
    不错。。学习了。。。。
    2010-08-13 07:35:13
给排水资料库
22.46 万条内容 · 568 人订阅
《城市给水工程规划规范》GB 50282-98
《城市给水工程规划规范》GB 50282-98(chm格式)
