土木在线论坛 \ 建筑结构 \ ANSYS \ ansys9。0安装问题求助帖
ansys9。0安装问题求助帖
发布于:2006-12-07 20:58:07 来自:建筑结构/ANSYS [复制转发]
在配置环境时运行ANSYS Licensing Administration Utility时可以顺利读取license文件,但是到启动license manageer的时候就出错,显示无法启动。防止我表达得不明确,我把这个过程中ANSYS Licensing Administration Utility所记录的内容copy如下:
Dec 07, 2006 20:48: Summary of License Wizard run:
Welcome to the ANSYS License Wizard
The License Wizard will take you through the following steps:
1. Install the license file.
2. Automatically specify the local machine as the license server.
3. Start the license manager or reread the license file.
When available, you may use the <Skip> button to skip the current step.
Choose <Continue> to begin Step 1...
Step 1: Install the license file.
NOTE: A valid license file is not currently installed on this system.
This step is required to continue.
Choose <Continue> to install the license file...
... License file installed successfully
Step 2: Automatically specify the local machine as the license server
(i.e., update the ansyslmd.ini file).
Choose <Continue> to automatically specify the license server...
An entry already exists for license server: lenovo-d736ad24
... Server specification not added.
Step 3: Start the license manager:
NOTE: For changes to the license file to take effect,
you must start the license manager.
Choose <Continue> to start the license manager...
Dec 07, 2006 20:48: Attempting to start the license manager...
Start the License Manager status:
The license manager failed to start.
You may examine the license log file for more information or possible
errors (by clicking the ’View Status/Diagnostic Options’ button). Additionally,
you can reference the Troubleshooting section in the ANSYS Licensing
Guide for more details.
Wizard complete...
Choose <Finish> to exit the wizard and write the wizard log data to the session log.
拜托各路高手帮忙看下
  • pxchi@co163
    pxchi@co163 沙发
    另外我把license贴出来,不知道是不是license有问题(或过期了:因为里面的2006.0910 使我有点怀疑,如果真是license的问题,还望高手指明解决办法)
    SERVER LENOVO-D736AD24 00163676942e 1055
    VENDOR ansyslmd "C:\Program Files\Ansys Inc\Shared Files\Licensing\intel\ansyslmd.exe"
    INCREMENT ane3fl ansyslmd 2006.0910 permanent 10 194DA5D4565D \
    VENDOR_STRING=customer:00254811 ISSUED=28-Nov-2004 \
    START=28-Nov-2004
    INCREMENT ansys ansyslmd 2006.0910 permanent 10 261D4CCDC86B \
    START=28-Nov-2004
    INCREMENT emag ansyslmd 2006.0910 permanent 10 3CBECBA554AC \
    START=28-Nov-2004
    INCREMENT flotran ansyslmd 2006.0910 permanent 10 C4B0221C7D2F \
    START=28-Nov-2004
    INCREMENT preppost ansyslmd 2006.0910 permanent 10 2D262C03C335 \
    START=28-Nov-2004
    2006-12-07 21:07:07
ANSYS
4.39 万条内容 · 152 人订阅
Ansys高级工程应用实例分析及二次开发
Ansys高级工程应用实例分析及二次开发,阚前华,谭长建,张娟,董城编著。  全书首先介绍了有限元分析法,ANSYS、APDL基础知识;然后分土木工程、机械工程、材料工程、水利工程、电子工程5大专业,分别阐述了各专业的工程背景和ANSYS在上述领域的强大分析能力;最后,详细介绍了ANSYS的二次开发,并对大多数常见问题给予详细解答
