土木在线论坛 \ 注册考试 \ 注册土木工程师 \ 土木工程专业视频教学下载网址
土木工程专业视频教学下载网址
发布于:2006-12-05 12:53:05 来自:注册考试/注册土木工程师 [复制转发]
一个不错的土木工程专业视频教学下载网址,发放给大家共享哦!
http://www.abab123.com/bbs/down.asp?html=445798
  • bagyu
    bagyu 沙发
    是不是免费的哦!
    2006-12-18 12:50:18
注册土木工程师
6.76 万条内容 · 269 人订阅
危拱坝改型后的特性(英汉对照)
PERFORMANCE OF RETROFITTED DETERIORATED ARCH DAMBy Avinash C. Singhal, Fellow, ASCE, and Larry K. Nuss ABSTRACT: The Stewart Mountain Dam is a 212 ft (64.6 m) high multi-curvature thin arch dam. The structure was completed in 1930. It has experienced alkali-silica reactions within the concrete and exhibited no bond across horizontal construction lift surfaces. The dam could be subjected to upgraded maximum credible earthquake (MCE) or probable maximum flood (PMF) loadings. Alkali-silica reactions and expansions have caused visible surface cracking. Several measures for prevention of further deterioration and strengthening were considered. Post-tensioned cables were selected to provide seismic strengthening. Cable design uses the stiffness, and acceleration response spectra methods. Vertical post-tensioned cables were installed during 1990-92 construction phase. This paper summarizes various field and laboratory investigations, structural analyses, and design parameters needed for post-tensioning a deteriorated arch dam. Post-tensioned cables are found to be a viable solution for the dynamic stability of a thin-arch dam. Methodology presented in this paper is applicable to other deteriorated dams.
