土木在线论坛 \ 建筑设计 \ 3dmax/sketchup \ SU渲染插件测试版
SU渲染插件测试版
发布于:2006-11-04 23:15:04 来自:建筑设计/3dmax/sketchup [复制转发]
插件名Podium
相关中文网站连接http://www.aitop.com/post/view?bid=55&id=79558&tpg=1&ppg=1&sty=1#79559
目前测试版只能渲染640*480的图
You can now make TRUE photo-realistic rendering of your SketchUp model without the pain and frustration of learning a complex program. Podium runs completely inside SketchUp from start to finish. It uses SketchUp features such as textures, background colors, groups and shadows to achieve impressive results. Podium is intuitive to SketchUp users. Plus, its simple interface cuts the learning curve to minutes instead of days. Make an impression without the pain.
全部回复(46 )
  • chobitstianming
    顶!!!!!
    2008-12-11 15:23:11
  • magaotao_1984
    magaotao_1984 板凳
    太棒了,请问各位大虾,这个能不能渲染出,带线框的效果?
    2008-11-21 08:52:21
3dmax/sketchup
5.2 万条内容 · 91 人订阅
急!3D出问题!!
高手你好~我是初学者!我建的一个模型~不能正常渲染!只能最高渲2000X1500的图~~再往大的渲,它就提示"error creating bitmap"很棘手的问题!! 跪谢高手了!!!
