土木在线论坛 \ 建筑结构 \ ANSYS \ ansys 接触问题不收敛 求助!!
ansys 接触问题不收敛 求助!!
发布于:2012-04-02 20:19:02 来自:建筑结构/ANSYS [复制转发]
finish
/clear
/filname,dangenmaoganshiyan1
/title,paper
*afun,deg
/prep7
r0=100
r1=20
l0=6000
et,1,plane42
et,2,solid45
et,3,conta173
keyopt,3,1,0
keyopt,3,12,2
et,4,targe170
!钢筋
mptemp,1,0
mp,ex,1,2.0e11
mp,nuxy,1,0.3
!mp,dens,1,9870
mp,mu,1,0.5
!tb,biso,1 !定义了双线性等向强化材料
!tbdata,1,930e6,
!/xrange,0,0.01
!tbplot,biso,0
!砂浆
mp,ex,2,2.63e10
mp,nuxy,2,0.19
!mp,dens,2,2100
mp,mu,2,0.75
!tb,dp,2,,,
!tbdata,1,530000,37,34
!基岩
mp,ex,3,3.3e10
mp,nuxy,3,0.2
!mp,dens,3,2780
mp,mu,3,0.5
!tb,dp,3,,,
!tbdata,1,900000,39,35
!建模
k,1000,0,0,0
circle,1000,100
circle,1000,20
l,1,5
l,2,6
l,3,7
l,4,8
a,1,2,6,5
a,2,3,7,6
a,3,4,8,7
a,4,1,5,8
lsel,s,line,,1,4,1
lsel,a,line,,5,8,1
lsel,a,line,,9,12,1
lesize,all,,,3
amesh,all
extopt,esize,60,0
type,2
mat,2
extopt,aclear,1
vext,1,4,1,,,6000 !1michang
circle,1000,20
a,17,18,19,20
lsel,s,line,,33,36,1
lesize,all,,,3 !钢筋划分网格
type,1
amesh,21
extopt,esize,60,0
type,2
mat,1
extopt,aclear,1
vext,21,,,,,6000 !6michang
vsel,s,volu,,5,,
vplot
allsel,all
vplot
csys,0 !注意这的坐标系
circle,1000,800
circle,1000,100
l,25,29
l,26,30
l,27,31
l,28,32
a,25,26,30,29
a,26,27,31,30
a,27,28,32,31
a,28,25,29,32
lsel,s,line,,45,48,1
lsel,a,line,,49,52,1
lesize,all,,,3
lsel,s,line,,53,56,1
lesize,all,,,10,1.2
allsel
aplot
asel,s,area,,27,30,1
aplot
type,1
amesh,all
extopt,esize,60,0
type,2
mat,3
extopt,aclear,1
vext,27,30,1,,,6000 !1michang
vsel,s,volu,,6,9,1
vplot
allsel,all
vplot
!接触对的生成
r,1
RMODIF,1,13,530*1000 !定义初始凝聚力
RMODIF,1,9,650*1000 !定义等效剪应力
real,1
vsel,s,mat,,2
vplot
asel,s,area,,8,,
aplot
cm,target,area
type,4
mat,2
nsla,s,1
esurf,all
allsel,all
vsel,s,mat,,1
vplot
asel,s,area,,23,,
aplot
cm,contact,area
type,3
mat,1
nsla,s,1
esurf,all
r,2
RMODIF,2,13,530*1000 !定义初始凝聚力
RMODIF,2,9,650*1000 !定义等效剪应力
real,2
vsel,s,mat,,2
vplot
asel,s,area,,13,,
aplot
cm,target,area
type,4
mat,2
nsla,s,1
esurf,all
allsel,all
vsel,s,mat,,1
vplot
asel,s,area,,24,,
aplot
cm,contact,area
type,3
mat,1
nsla,s,1
esurf,all
r,3
RMODIF,3,13,530*1000 !定义初始凝聚力
RMODIF,3,9,650*1000 !定义等效剪应力
real,3
vsel,s,mat,,2
vplot
asel,s,area,,17,,
aplot
cm,target,area
type,4
mat,2
nsla,s,1
esurf,all
allsel,all
vsel,s,mat,,1
vplot
asel,s,area,,25,,
aplot
cm,contact,area
type,3
mat,1
nsla,s,1
esurf,all
r,4
RMODIF,4,13,530*1000 !定义初始凝聚力
RMODIF,4,9,650*1000 !定义等效剪应力
real,4
vsel,s,mat,,2
vplot
asel,s,area,,20,,
aplot
cm,target,area
type,4
mat,2
nsla,s,1
esurf,all
allsel,all
vsel,s,mat,,1
vplot
asel,s,area,,26,,
aplot
cm,contact,area
type,3
mat,1
nsla,s,1
esurf,all
!外接触
r,5
RMODIF,5,13,900*1000 !定义初始凝聚力
RMODIF,5,9,1000*1000 !定义等效剪应力
real,5
vsel,s,mat,,3
vplot
asel,s,area,,34,,
aplot
cm,target,area
type,4
mat,3
nsla,s,1
esurf,all
allsel,all
vsel,s,mat,,2
vplot
asel,s,area,,6,,
aplot
cm,contact,area
type,3
mat,2
nsla,s,1
esurf,all
r,6
RMODIF,6,13,900*1000 !定义初始凝聚力
RMODIF,6,9,1000*1000 !定义等效剪应力
real,6
vsel,s,mat,,3
vplot
asel,s,area,,39,,
aplot
cm,target,area
type,4
mat,3
nsla,s,1
esurf,all
allsel,all
vsel,s,mat,,2
vplot
asel,s,area,,11,,
aplot
cm,contact,area
type,3
mat,2
nsla,s,1
esurf,all
r,7
RMODIF,7,13,900*1000 !定义初始凝聚力
RMODIF,7,9,1000*1000 !定义等效剪应力
real,7
vsel,s,mat,,3
vplot
asel,s,area,,43,,
aplot
cm,target,area
type,4
mat,3
nsla,s,1
esurf,all
allsel,all
vsel,s,mat,,2
vplot
asel,s,area,,15,,
aplot
cm,contact,area
type,3
mat,2
nsla,s,1
esurf,all
r,8
RMODIF,8,13,900*1000 !定义初始凝聚力
RMODIF,8,9,1000*1000 !定义等效剪应力
real,8
vsel,s,mat,,3
vplot
asel,s,area,,46,,
aplot
cm,target,area
type,4
mat,3
nsla,s,1
esurf,all
allsel,all
vsel,s,mat,,2
vplot
asel,s,area,,19,,
aplot
cm,contact,area
type,3
mat,2
nsla,s,1
esurf,all
allsel,all
eplot
!求解设置
/solu
!设置约束
aplot
da,all,all
allsel
asel,s,area,,32,,,
asel,a,area,,37,,,
asel,a,area,,41,,,
asel,a,area,,45,,,
aplot
da,all,symm
da,all,all
alls
dtran
!施加荷载
allsel,all
!acel,0,0,9.8
asel,s,area,,22,,
aplot
f0=500*1000 !加载方式500
a0=3.14*r1**2
sfa,all,,pres,-f0/a0
allsel,all
ftran
lswrite
asel,s,area,,22,,
aplot
f0=500*1000 !加载1000
a0=3.14*r1**2
allsel,all
ftran
lswrite
asel,s,area,,22,,
aplot
f0=500*1000 !加载1500
a0=3.14*r1**2
allsel,all
ftran
lswrite
!设置求解选项
allsel,all
antype,static
nlgeom,on
!EQSLV, PCGOUT,1.0e-5,0, !选用预条件共轭梯度求解器PCG求解
time,1
nsub,100,500,10
autots,on
neqit,50
cnvtol,f,,0.05,2,2, !cnvtol,f,100,0.05,2,,
nropt,full,,on
outress,all,10
pred,on
lnsrch,on
alls
lssolve,1,3
save
不收敛啊,请问是哪一步出错了呢?
ANSYS
4.39 万条内容 · 152 人订阅
钢结构设计规范 ansys结果
我看到钢结构设计规范中的稳定性公式中需要求N和M,此外还有系数,如果用ansys进行分析,结果计算的应力与钢结构中用N和M计算的应力不一致吧,以哪个计算结果为准呢,本人菜鸟,所以问个基本问题,请高手指点
