土木在线论坛 \ 给排水工程 \ 给排水资料库 \ 无机絮凝剂除磷机理综述(英文)
无机絮凝剂除磷机理综述(英文)
发布于:2011-12-07 17:54:07 来自:给排水工程/给排水资料库 [复制转发]
论文简介:
This paper reviews the use of pre-polymerised inorganic coagulants in water and waste-water treatment, and discusses the removal
of phosphorus by chemical precipitation and coagulation. Commonly used inorganic coagulants are aluminium or iron (III) based
salts, but a range of hydrolysed Al/Fe species, and not the Al/Fe salt itself, are responsible for the removal of impurities from water.
By the development and use of polymeric inorganic coagulants, the coagulation performance can be improved significantly in
some cases. Chemical precipitation and coagulation in phosphorus removal are two different processes, with the former related to
the compound solubility and the latter depending on the destabilisation-adsorption mechanism. Presently, there is uncertainty
concerning the mechanisms and overall performance of phosphorus removal by pre-polymerised metal coagulants.
附件名:20111271323251665046.zip
文件大小:113K
(升级VIP 如何赚取土木币)
全部回复(4 )
  • y328428508
    y328428508 沙发
    lolicat 发表于 2012-4-20 19:56 只是英文的啊。。。。。求中文翻译求中文翻译
    2013-02-26 10:04:26
  • lolicat
    lolicat 板凳
    只是英文的啊。。。。。
    求中文翻译
    2012-04-20 19:56:20
给排水资料库
22.46 万条内容 · 568 人订阅
陶瓷垫片在箱型梁制作安装中得应用
论文简介: 环形箱梁是POC型新型干式煤气柜活塞体的重要构件,我司在环形箱梁的安装焊接中,因陶瓷衬垫适应性强,使用方便,焊缝外观成形良好,焊接接头机械性能能够满足规范要求,并可大大提高生产效率,降低生产成本等原因,使用了焊接用陶瓷衬垫,得到了良好的效果。在此介绍采用陶瓷衬垫焊接的环形箱梁的安装及焊接工艺特点。 附件名:20111271323240564375.zip 文件大小:446K
