土木在线论坛 \ 建筑结构 \ ANSYS \ ansys10.0安装错误-急盼高手解救
发布于:2006-08-17 14:54:17 来自:建筑结构/ANSYS [复制转发]
我按照安装步骤安装完程序后,运行时出现下列错误,请高手指点迷津:
*** FATAL *** CP = 0.961 TIME= 12:26:29
The database (-db) space requested is not currently available.
Reenter ANSYS command line with less database space requested.
The above error is non-recoverable by ANSYS
ANSYS run terminated by the indicated error
Current data base saved if possible.
/COM,ANSYS RELEASE 10.0 UP20050718 12:27:24 08/17/2006
  • loryie
    loryie 沙发
    要现运行ANSYS Product Launcher,试试
    2006-08-20 10:02:20
ANSYS
4.39 万条内容 · 152 人订阅
缺边井字梁可行性做法讨论
诸位,在一房间内你们是否做过这样形状的梁,大家来研究一下它的可行性下面的梁形似井字梁,只是缺了边,自定义为缺边井字梁
